Is there a way to quickly select all edges associated with a face?
For instance, if I have someone else's mesh (thingiverse STL), converted to a solid (Part WB), and am unlucky enough that the file has a bajillion chamfers, and I want to remove features using the Draft WB to downgrade the solid to faces and the Defeaturing WB/toolbar to remove and reconstruct faces. Inevitably, I'll need to modify a few faces that have like 100 edges. I really wish I had a way to select all the edges of a face from the face. Something like "<ALT>+left-click" to select edges from a face. Is there something like this available? I've encountered this a couple of times in recent weeks.
-Jake
Re: Is there a way to quickly select all edges associated with a face?
No direct answer to your question, but I see it again and again that people invest much time in order to convert STLs to FreeCAD objects. And the final result is at its best a poorly tesselated object.
I recommend to head for a finally good model by converting the stl to a shape and use that as reference for a new - real - FreeCAD model.
if nothing else one can always resort to scripting...
# one face selected
s, = Gui.Selection.getSelectionEx()
obj = s.Object
face, = s.SubObjects
Gui.Selection.clearSelection()
hits = list()
for fe in face.Edges:
for i, edge in enumerate(obj.Shape.Edges, start=1):
if fe.isEqual(edge):
hits.append('Edge{}'.format(i))
edge.reverse()
Gui.Selection.addSelection(obj, hits)
It took me awhile to figure out when it is better to rebuild versus modify. I still get it wrong most times. Watching Mark Ganson's youtube stuff helped me see the relationship between wires faces and solids https://www.youtube.com/c/mwganson. My resulting prints have come out useful.chrisb wrote: ↑Wed Jun 16, 2021 9:38 pm No direct answer to your question, but I see it again and again that people invest much time in order to convert STLs to FreeCAD objects. And the final result is at its best a poorly tesselated object.
You are a god and a gentleman! That works perfectly. Now I just need it in a pretty button. CTRL+V certainly works well for me now. THANKS!!!
-Jake
You can configure your own buttons for your own macros, see Customize Toolbars.
Hi
you work with many STL file , maybe this macro can also help you
(I made this macro for another user but I think I misunderstood his need)
select your object and click the face interesting for convert in a Shape face
you have options create point, triangle, triangle face, color
EDIT 17/06/2021 11h21 modify the code adding line option
mario
#Mesh_Face_to_Shape_Face
#https://forum.freecadweb.org/posting.php?mode=reply&f=3&t=59475#preview
#original macro https://wiki.freecadweb.org/Code_snippets#Get_the_normal_vector_of_a_surface_from_a_STL_file
#Mario52
#15/06/2021; 17/06/2021
from pivy import coin
import warnings
warnings.simplefilter("ignore")
import Draft
#### Config ####
global point ; point = 0 # if 1 create points
global triangle; triangle = 0 # if 1 create triangle (1 by default)
global faces ; faces = 1 # if 1 create face (1 by default)
global couleur ; couleur = 1 # if 1 create face colored (1 by default)
#### Config ####
global meth
global v, c
v=Gui.activeDocument().activeView()
class ViewObserver:
def logPosition(self, info):
global v, c
global meth
try:
down = (info["Key"])
if down == "ESCAPE":
v.removeEventCallback("SoEvent",c) # remove ViewObserver SoEvent
Gui.ActiveDocument.ActiveView.removeEventCallbackPivy(coin.SoMouseButtonEvent.getClassTypeId(), meth) # remove SoMouseButtonEvent
FreeCAD.Console.PrintMessage("Quit Mesh_Face_to_Shape_Face" + "\n")
except Exception:
None
o = ViewObserver()
c = v.addEventCallback("SoEvent",o.logPosition)
##v.removeEventCallback("SoEvent",c) # remove ViewObserver SoEvent
def makeTriangle(cb):
import Draft
global point
global triangle
global couleur
pp = cb.getPickedPoint()
try:
if pp: # and (pp != None):
objs = FreeCADGui.Selection.getSelection()
if hasattr(objs[0], "Mesh"): # upgrade with wmayer thanks #http://forum.freecadweb.org/viewtopic.php?f=13&t=22331
index = coin.cast(pp.getDetail(), "SoFaceDetail").getFaceIndex()
#print("Mesh")
s = objs[0].Mesh
coordPoints = s.Facets[index].Points
if point == 1:
Draft.makePoint(coordPoints[0][0], coordPoints[0][1], coordPoints[0][2])
Draft.makePoint(coordPoints[1][0], coordPoints[1][1], coordPoints[1][2])
Draft.makePoint(coordPoints[2][0], coordPoints[2][1], coordPoints[2][2])
if triangle == 1:
points = [FreeCAD.Vector(coordPoints[0][0], coordPoints[0][1], coordPoints[0][2]),
FreeCAD.Vector(coordPoints[1][0], coordPoints[1][1], coordPoints[1][2]),
FreeCAD.Vector(coordPoints[2][0], coordPoints[2][1], coordPoints[2][2])]
line = Draft.makeWire(points, closed=True, face=False, support=None)
FreeCAD.ActiveDocument.getObject(line.Name).Label = "Triangle_" + str(index)
if couleur == 1:
FreeCADGui.ActiveDocument.getObject(line.Name).LineColor = (0.8000,0.0000,0.0000)
Draft.autogroup(line)
if faces == 1:
line = Draft.makeWire(points, closed=True, face=True, support=None)
FreeCAD.ActiveDocument.getObject(line.Name).Label = "Face_" + str(index)
if couleur == 1:
FreeCADGui.ActiveDocument.getObject(line.Name).ShapeColor = (0.8000,0.0000,0.0000)
FreeCAD.ActiveDocument.recompute()
else:
FreeCAD.Console.PrintMessage("Select Mesh object" + "\n")
except Exception:
None
meth=Gui.ActiveDocument.ActiveView.addEventCallbackPivy(coin.SoMouseButtonEvent.getClassTypeId(), makeTriangle)
##Gui.ActiveDocument.ActiveView.removeEventCallbackPivy(coin.SoMouseButtonEvent.getClassTypeId(), meth)
FreeCAD.Console.PrintMessage("\n" + "Type ESCAPE for quit Mesh_Face_to_Shape_Face" + "\n\n")
nino problema
@mario52 - nice - actually so nice that it really should be part of mesh wb imho (dropdown toolbar icon for the different choices?)
since faster is better, did the obvious code mods that should do a bit on speed,
on the smaller test case used - it did close to 30%
# one face selected
obj = s.Object
hits = list()
Edge = 'Edge{}'.format
objEdges = tuple(obj.Shape.Edges)
feisEqual = fe.isEqual
for i, edge in enumerate(objEdges, start=1):
if feisEqual(edge):
hits.append(Edge(i))
break
edge.reverse()
if feisEqual(edge):
break
