I'm trying to model a VESA mount, but I'm having trouble connecting some vertices of arcs crossing circles, see the red squares in the following image. I found out that I had open vertices by using the 'validate sketch' function.
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I have tried and retried to constrain the arc in different ways hoping that the vertices close, but nothing worked. I have tried using the point on an object constrained, making a point on the intersection between the circle and the construction line and than using the coincident restraint to tie the end of the arc to that point and I tried to make the 'Close Shape' tool work. I tried finding the solution on the forum and I found similar problems, but none of those solutions worked for me. Does anyone have any idea how I can solve this?
OS: Windows 10 Version 2009Close vertices of an arc crossing with a circle in a sketch
- Vesa mount.FCStd
- (10 KiB) Downloaded 10 times
Re: Close vertices of an arc crossing with a circle in a sketch
Hi and welcome to the forum!
If you want to pad the sketch it must not have any crossings or T-joins. This is an example that pads:
- SnipScreenshot-eba344.png (36.46 KiB) Viewed 356 times
Well now that I think about it that makes a lot of sense, thanks!
