assembly and multiple spreadsheets
I am trying to assemble parts in free cad. As I understand it, you have to create each part as a separate file (a2plus). This is a problem in that I want to have one spreadsheet with all of the variables so that when I change something it will automatically change everything relevant. Can someone give me some direction on this? would another assembly work bench be better? I am just doing simple wood working. thanks!
Re: assembly and multiple spreadsheets
Put the spreadsheet in a separate file, so all the designs reference one set of parameters.
https://wiki.freecadweb.org/Spreadsheet_Workbench
You can reference spreadsheet data from an external file with this syntax: =NameOfFile#<<MySpreadsheet>>.MyAlias.
The advantage of having the spreadsheet in another file over switching off recomputes is that the spreadsheet itself does get recomputed.
The disadvantage is that the model won't automatically recompute after changes to the spreadsheet.
In the scenario where you first open the 'spreadsheet' file, change one or more values and then open the 'model' file, there won't be any indication that the model needs to be recomputed. But if both files are open the Std Refresh icon will update correctly for the 'model' file after changes to the 'spreadsheet' file.
Thanks for the help. I tried your example but it did not work. could you give a real world example from a windows10 perspective?
These files created in Win10. Make sure both files open in FreeCAD, as described in above wiki page.
If you need more help,please follow forum guidelines and post your FreeCAD about info and in addition, please post the model your need help with and a much clearer description of what you need help with as "did not work" does not give any information to help Forum users help you.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I guess that you could create links to the spreadsheet too. That's how I'm working with Spreadsheets if I'm creating the assembly in another file and want to get data from a Spreadsheet in one of the files containing the actual models.
Regards / Viele Grüße
Max
Max
