I'm trying to loft a sketch with two perimeters to another sketch with two perimeters, but the loft always crosses the outer perimeter of one to the inner perimeter of the other,
In the attached file, if you attempt to loft:
Sk_GMF_Rim_Start to Sk_GMF_Rim_Surface
or
Sk_GMF_Rim_Surface to Sk_GMF_Rim_Top
It fails, crossing from the lower outside rim to the upper inside rim.
However, the following succeeds:
Sk_GMF_Rim_Start to Sk_Rim_Top
Is there a better way to do this?
Loft failure -- inner/outer rims crossed
- Bug_LoftCross_1.FCStd
- (30.07 KiB) Downloaded 11 times
Re: Loft failure -- inner/outer rims crossed
Forgot the freecad info:
OS: FreeBSD 11.4-RELEASE-p6 (XFCE/xfce)
Version: 0.19.0.19.1
Python version: 3.7.9
Qt version: 5.15.2
OCC version: 7.5.0
Locale: C/Default (C)
Qt version: 5.15.2
OCC version: 7.5.0
There is no loft in the file. Note that when using inner and outer loops in a loft, you have to draw inner and outer in the same sequence in both (better: all) of the sections.
What will likely fix it is to create the inner and outer outlines in the same order in each sketch.
Thanks, that was it.edwilliams16 wrote: ↑Fri Jun 18, 2021 4:38 am What will likely fix it is to create the inner and outer outlines in the same order in each sketch.
The middle section (Sk_GMF_Rim_Surface) had the inner rectangle created first; the others had the outer rectangle created first.
