I'm trying to create a model with serrations similar to those in the attached images but I have not been able to do it. Note that the serrations are radial - that is my downfall.
How can this be done?
tia
Kevin
[SOLVED] Need help creating serations
- Screenshot_20210618_095124.png (62.62 KiB) Viewed 750 times
- Screenshot_20210618_094854.png (27.42 KiB) Viewed 750 times
Re: Need help creating serations
Cut one groove then https://wiki.freecadweb.org/PartDesign_PolarPattern
OK, but I've got a mental block on how to draw the first groove. I can do it if it's straight bit not radially.
I made two nested polygons and lofted a triangle between two corresponding faces, then did a polar pattern. To make the edges circular, I pocketed them. I've no doubt there's a better way - I'm still a neophyte.
- radialpattern.FCStd
- (221.19 KiB) Downloaded 16 times
I remember at least two other discussions on this topic; you may search for Hirth joint.
- papyblaise
one more idée
- rachet.FCStd
- (288.5 KiB) Downloaded 15 times
- rachet.PNG (14.4 KiB) Viewed 644 times
Hirth joint - never heard of it before but that is exactly what I need.
For the record, I found this video that explains it very well: https://youtu.be/SEnCLU8moN4
Thanks for you help, much appreciated!
Re: [SOLVED] Need help creating serations
hi
How to make a hirth joint?
Work project is kicking my butt
Hirth joint (macro)
Repeating pattern on a cylinder (macro)
mario
Hirth joint (macro)
mario
