Can't pad mirrored sketch
drmacro
Re: Can't pad mirrored sketch
Post by drmacro »
jgauthier wrote: Sat Jun 19, 2021 11:59 am ...
Thanks for all the help, everyone. I am going to start fresh and try to get the imported object centered and see if that helps my mission.
Would it be possible to link to the stl in question?
Or, attach it to a post here?
jgauthier
Post by jgauthier »
Oh yeah, sure. I initially tried to post the FreeCAD model, but it got very large after importing.
bl_touch_mount.stl
(475.67 KiB) Downloaded 22 times
drmacro
Post by drmacro »
jgauthier wrote: Sat Jun 19, 2021 1:59 pm Oh yeah, sure. I initially tried to post the FreeCAD model, but it got very large after importing.
As is so typical of stl files...it is not manifold. :cry:
Tek3D
Post by Tek3D »
I'm not sure, but it sounds like you're still ending up with a multi-body part somehow. Include your feature tree with the screen shot next time, that would help. I repeated the same steps already described here, and it worked (although it was a bit slow).
stl mod - Copy.jpg (123.15 KiB) Viewed 478 times
jgauthier
Post by jgauthier »
Tek3D wrote: Sat Jun 19, 2021 3:10 pm I'm not sure, but it sounds like you're still ending up with a multi-body part somehow.
Well look at that. you're right.
drmacro
Post by drmacro »
So, have you used Part>Check geometry with the BOP option checked?
Select the Body and give it a try...
