Simple drawing failing to export to 2D .DXF
run_the_race
Post by run_the_race »
I have flattened some sheetmetal parts, and other complex drawings, and they exported to 2D .DXF no problem.
However now I have a very simple plate, and its failing to export. I simplified the drawing and attached it.
This is the drawing:
And this is how it gets exported:
OS: Windows 10 Version 2004
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
export_dxf.FCStd
(17.49 KiB) Downloaded 22 times
drmacro
Re: Simple drawing failing to export to 2D .DXF
Post by drmacro »
If you go to Preferences>Import/Export DXF tab.
Select legacy export and project along view.
THen switch to the side view, select the body, and export.
Looks ok here.
run_the_race
drmacro wrote: Sat Jun 19, 2021 2:50 pm If you go to Preferences>Import/Export DXF tab.
Looks ok here.
Thank you! I had "project exported objects along current view on", but didnt not try legacy python exporter cause it doesnt sound like a good option, but that did the trick!
freedman
Post by freedman »
For anyone out there looking to do some automated DXF exports. I used this macro to export one or multiple views from TechDraw. It exports to a Dir on your system and numbers the files for multiple views. It's currently set to export to "C:A_dxfs" but can be changed by editing the first real fileSpecDxf. If I remember correctly you need to select the target page then run the macro.
I used this alot on a big project. I would grab a bunch of views and bring them to TechDraw and then generate DXFs for AutoCad. Worked great!
Wandererfan generated the basic structure of the macro. Thanks to him.
dxf_out_to_file.FCMacro
(1.98 KiB) Downloaded 20 times
