I want to create a Loft between a triangle and a square. But I need to be able to control the silluette of Hull_XY and Hull_ZY, also be able to change the angle of the profile_bottom. I have tried using Loft and Sweep in PartDesign WB but they don't allow enough control. CurvedShapes WB gives mix results (most of the times it produces lines that doesn't intersect). I have tried to use the same amount of segments in the profile, I tried opened and closed hulls, reversing and rotating faces, separating Hulls. But I never get a good result. In the attached file I have simplified the problem.
(I have had this problem for over one year, it really haunts me)
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Swedish/Sweden (sv_SE)
Loft using hullcurves
- test.FCStd
- (11.32 KiB) Downloaded 30 times
- Shalmeneser
Re: Loft using hullcurves
It will be difficult to loft a triangle with a square. And the planes are not parallel.
What is the purpose of Hulls ?
If you explain your goal, perhaps other method can be found.
- Corpus delicti 23.png (24.73 KiB) Viewed 796 times
Hi, thank you for your reply. I'm trying to create the ear of a manchu bow (the utmost point of a bow). Historically they are triangles at the knee and rectangles at the nock. I want to test different profiles of the ear to reduce weight and optimize durability. Therefore I need to control the hulls in two planes. I could probably make profile_top and profile_bottom parallel then remove a wedge at the bottom when it's done, so parallel isn't super important. When FEM testing and 3d printing destruction tests are done I want to manufacture a mold in aluminum.t will be difficult to loft a triangle with a square. And the planes are not parallel.
- Antique manchu profile2.jpg (441.36 KiB) Viewed 778 times
- Pauvres_honteux
Sorry to be the "bringer of pain"! (was that Battle beast? )
The function "assign a point on section1 to another point /points on section2" is not implemented or even asked for (feature requested) yet. On top of that the direction of each section can not yet be altered, it also lacks a feature request. And just to really rub it in, we lack the possibility to set start and/or end tangency conditions for multi section surfaces.
However, the light in the tunnel (it's not a train) is that we can fix the request part of it. But we would need someone to dig into it, unfortunately so far it seems to be quite tough to dig that deep, even for our most decorated programmers.
But maybe you can do programming and have the energy to do so? Or someone you know would be intrested? Perhaps asking around among your chummies would give something?
The closest you can get today is via the Curves workbench by Chris_G.
- Shalmeneser
PartDesign doesn't seem to be the right workbench. PartDesign_AdditivePipe is too rough.
Try Surface / Curves / Silk?
You'll need Image_Module to put your different curves at the right place and copy forms.
- Corpus delicti 24.png (11.44 KiB) Viewed 735 times
When this is finished, it will be my magnum opus! I lack any programming skills, but I might have somewhat solved it with Curves workbench. I also used a boolean cut and some trigonometry to get my desired angle at the bottom. Still need to tweak it a bit more to get the square shape closer to the triangle.Pauvres_honteux wrote: ↑Sat Jun 19, 2021 9:56 pm Sorry to be the "bringer of pain"! (was that Battle beast? )
Copy forms and Curves Workbench seems to be the answer. The profiles had same amount of edges, but different positions (clockwise vs anticlockwise + starting point). Therefore it twisted and inverted itself.Shalmeneser wrote: ↑Sat Jun 19, 2021 10:26 pm PartDesign doesn't seem to be the right workbench. PartDesign_AdditivePipe is too rough.
Thank you for all of the help
- Skärmbild (192).png (155.22 KiB) Viewed 670 times
- test.FCStd
- (50.28 KiB) Downloaded 23 times
