I may have missed it, but can't currently see any references pointing this particular behavior.
(v. 0.2)
The attached drawing has a single "draft" line.
The length of the line can be changed at 1mm increments for as long as the length is less than 1000mm long.
Once the length is 1000 mm and over, it cannot be changed in increments of 1mm.
Once the length is 1000 mm and over, increment jumps to 10mm chunks.
For example:
Length can be 997, 998, 999, 1000 mm.
However length cannot be 1001mm. It can be 1010. It cannot be, say 1005mm.
It jumps from say 1000, to 1010, 1020, ad infinitum.
Thanks for any suggestions.
This behavior occurs in the following version (v 0.2)
OS: KDE neon User Edition 5.22 (KDE/plasma)
Version: 0.20.25065 (Git) AppImage
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.9.4
Qt version: 5.12.9
OCC version: 7.5.2
...but not in the following versions,
Version: 2021.615.24301 +3584 (Git) AppImage
Branch: LinkStage3
Hash: d1e4d1c5abdedda669e54d1a41b5c08077f7e561
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Version: 2021.615.24301 +3747 (Git) AppImage
Branch: LinkDaily
Hash: ecbfba008c481db4cb17bf8bd514b2d12690a8e5
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Length / Offset behavior in v. 0.2
- Line-Example_01.FCStd
- (6.18 KiB) Downloaded 14 times
Re: Length / Offset behavior in v. 0.2
Confirmed. The problem is related to the number of decimals used for units and how FreeCAD interprets user input.
Apparently 1001mm is converted to 1.001m, and if the number of decimals is 2 this is converted to 1.00m. Weird behavior IMO.
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks for checking this out.
I do think it's a show stopper kind of behavior.
I haven't studied how to start a bug confirmation process yet.
I hope more people can look into this, and offer their takes on the matter.
- Shalmeneser
