OpenSCAD to FreeCAD path generation on a sloping face
galgier
Post by galgier »
Yes, this is my first time trying to make a 3D part with OPenSCAD and FreeCAD. I am a definite noob.
I have defined a simple shape in OpenSCAD that consists of a wedge shape on top of a block. This means the top surface is sloping downhill towards the Y axis. All my attempts to use FreeCAD to generate a G Code milling path shows a simulation that zigzags or spirals around the face, once. This does not look like it would properly go from a height (Z) of 19.05 mm at one edge to a height of 6.35 mm at the other edge.
I think the path would need to start at one edge and traverse parallel to the edge taking a little off at one edge and then work towards the other edge where a lot needs to be taken off. It would need to make many passes along the final edge taking a little every pass. Any diagonal (such as with a zigzag) cuts would need to change the Z value as the bit is cutting.
I must be missing some basic concept of generating a path when the cuts need to be orthogonal and multi-pass.
Can someone help me understand how to generate a proper path?
Gary
keithsloan52
Re: OpenSCAD to FreeCAD path generation on a sloping face
Post by keithsloan52 »
galgier wrote: Sun Jun 20, 2021 6:53 pm Hello,
Gary
Suggest if you can you post your scad or csg file.
galgier
Post by galgier »
Below is the SCAD code. This is supposed to create a wedge shape on top of a slim block. This will be part of a spacer mounted behind something being placed against house siding. I will start with a board about 3/4 inches thick and take off the portion above the sloping face.
module triangle_prism(b,d,h,ht,sc)
    linear_extrude(height=ht,scale=sc)
    polygon(points=[[0,0],[b,0],[d,h]]);
module wedge(x,y,z)
    translate([0,y,0]) rotate([90,0,0]) triangle_prism(x,x,z,y,1);
module block(x,y,z)
    cube(size = [x,y,z]);
// convert to mm while we are at it
      depth = 0.5 * 25.4;
      minimum = 0.25 * 25.4;
      height = 4 * 25.4;
      width = 6 * 25.4;
module section(x,y,z)
    hull () {
        translate([0,0,minimum]) wedge(x,y,z);
        block(x,y,z);
section(height,width,minimum);
keithsloan52
galgier wrote: Wed Jun 23, 2021 11:14 pm Below is the SCAD code. This is supposed to create a wedge shape on top of a slim block. This will be part of a spacer mounted behind something being placed against house siding. I will start with a board about 3/4 inches thick and take off the portion above the sloping face.
module wedge(x,y,z)
module block(x,y,z)
      depth = 0.5 * 25.4;
      height = 4 * 25.4;
      width = 6 * 25.4;
    hull () {
        block(x,y,z);
Wondering if the hull operation is causing a problem as it results in the creation of a mesh, you could try replacing the hull request in the module section with a union.
withUnion.FCStd
(11.71 KiB) Downloaded 28 times
galgier
Post by galgier »
I chose hull because when I first did this I read some warning somewhere about slightly disjointed pieces causing problems. A union could do this, a hull won't.
The original project has three sections created trough replication and translation. What I posted was a simplified single section.
I decided to rewrite it with no unions or hulls, just one solid:
 Make a spacer to fit behind something to be mounted to
 the outside of a house.  It fills the gaps caused by
 the sawtooth pattern of siding.
 This will make three sections.
      maximum = 0.75 * 25.4;    // max thickness
      minimum = 0.25 * 25.4;    // min thickness
      height = 4 * 25.4;        // height of each siding piece
      width = 6 * 25.4;         // width of this device
translate([0,width,0])
rotate([90,0,0])
linear_extrude(height=width,scale=1)
polygon(points = [
    [ 0, 0 ],
    [ 0, minimum ],
    [ height, maximum ],
    [ height, minimum ],
    [ 2 * height, maximum ],
    [ 2 * height, minimum ],
    [ 3 * height, maximum ],
    [ 3 * height, 0 ]
This reduces the job to only one solid, but it does not solve the problem.
I think what I am running into is the step value in the cutting with the tool. Path generation sets a 3.00 mm step and it can't be changed. For things I have already done with my mill (Genmitsu 3018) I have used a Z step / pass of 0.7mm. Where does one enter the constraints like maximum horizontal rate, spindle speed, Z step, etc? Anything I have seen seems to be read-only parameters.
Gary
one-piece.FCStd
(18.6 KiB) Downloaded 23 times
keithsloan52
galgier wrote: Sat Jun 26, 2021 4:53 pm
Gary
In which case I think you might get a better response in Path/CAM section https://forum.freecadweb.org/viewforum.php?f=15
I completely missed this topic due to the OpenSCAD keyword in the title, which finally has nothing to do with the question. Moved to Path forum.
For such shapes you need a Path 3DSurface operation. Even better would be to span the stock sloped so you can mill 3 steps of a stair.
sliptonic
Post by sliptonic »
All the values can be changed. When you see a value in blue, that's the result of an expression being evaluated. Click on the icon in the corner of the input field to change the expression. You can clear it an enter any value you want.
keithsloan52
chrisb wrote: Mon Jun 28, 2021 1:49 pm I completely missed this topic due to the OpenSCAD keyword in the title, which finally has nothing to do with the question. Moved to Path forum.
Still seems to be in General Help, rather than Path
GeneFC
Post by GeneFC »
keithsloan52 wrote: Mon Jun 28, 2021 3:56 pm Still seems to be in General Help, rather than Path
Moved.
