Mirror with any plane (part wb)
mario52
Re: Mirror with any plane (part wb)
Post by mario52 »
Hi
make request :
Plane mirror:
Plane XY
Plane XZ
Plane YZ
Plane on selected face
volunter ?
mario
openBrain
Post by openBrain »
chrisb wrote: Mon Jun 21, 2021 9:37 am Thanks for the trick with the line indicating the direction
As a simplification it is possible to use for the Base of the mirror a single expression: plane.Placement.Base.
Indeed. As a further improvement, you can use :
For base : '<<MirrorPlane>>.Base.Placement' -- as stated by chrisb
For normal : '<<MirrorAxis>>.Shape.Curve.Direction'
EDIT : attach improved file
multisection _OB.fcstd
(591.74 KiB) Downloaded 22 times
openBrain wrote: Mon Jun 21, 2021 9:47 am For base : '<<MirrorPlane>>.Base.Placement' -- as stated by chrisb
Thanks!
For those not knowing how to set an expression for a compound property:
- Right click in the property panel, select "Show all"
- Right click on the property name (not the value) and select "Expression ..."
Roy_043
Post by Roy_043 »
... Or click in the field and then click the f(x) button.
UR_
Post by UR_ »
Or simply
- select Part object to mirror (cube in your example)
- select Part:plane
- hit
Screenshot 001.png (19.15 KiB) Viewed 973 times
from Lattice2 WB ... Done!
Full parametric mirror object is created.
edwilliams16
Post by edwilliams16 »
Screen Shot 2021-06-21 at 12.00.00 PM.png (78.95 KiB) Viewed 947 times
Screen Shot 2021-06-21 at 12.02.14 PM.png (56.49 KiB) Viewed 947 times
For others wondering just how this all worked, <<MirrorAxis>> is a construction line created to provide the normal direction to <<MirrorPlane>> attached to the object to be mirrored. Expressions were then used to locate the mirror plane for the mirroring operation.
Roy_043 wrote: Mon Jun 21, 2021 12:39 pm ... Or click in the field and then click the f(x) button.
:oops: You are right. I was still thinking of Placement, which doesn't have this button.
Vincent B
Post by Vincent B »
draft mirror like this. :D
mirror.FCStd
(45.36 KiB) Downloaded 14 times
DraftMirror.FCStd
(48.01 KiB) Downloaded 17 times
