Hi
make request :
Plane mirror:
Plane XY
Plane XZ
Plane YZ
Plane on selected face
volunter ?
mario
Mirror with any plane (part wb)
Re: Mirror with any plane (part wb)
Indeed. As a further improvement, you can use :
For base : '<<MirrorPlane>>.Base.Placement' -- as stated by chrisb
For normal : '<<MirrorAxis>>.Shape.Curve.Direction'
EDIT : attach improved file
- multisection _OB.fcstd
- (591.74 KiB) Downloaded 22 times
Thanks!
For those not knowing how to set an expression for a compound property:
- Right click in the property panel, select "Show all"
- Right click on the property name (not the value) and select "Expression ..."
... Or click in the field and then click the f(x) button.
Or simply
- select Part object to mirror (cube in your example)
- select Part:plane
- hit
from Lattice2 WB ... Done!
Full parametric mirror object is created.
- select Part:plane
- hit
For others wondering just how this all worked, <<MirrorAxis>> is a construction line created to provide the normal direction to <<MirrorPlane>> attached to the object to be mirrored. Expressions were then used to locate the mirror plane for the mirroring operation.
You are right. I was still thinking of Placement, which doesn't have this button.
draft mirror like this.
- mirror.FCStd
- (45.36 KiB) Downloaded 14 times
- DraftMirror.FCStd
- (48.01 KiB) Downloaded 17 times
