Mirror with any plane (part wb)
How to mirror an object with any plane (or datum plane) in part wb?
Or this feature is missing?
- Capture.JPG (32.43 KiB) Viewed 1363 times
Re: Mirror with any plane (part wb)
You can change the Normal of the plane in the properties later. Or use Draft_Mirror.
Not easy to get the normal vector.
I agree.
hi
Macro_Normal_Vector
mario
Macro_Normal_Vector
Gui.Selection.getSelectionEx()[0].SubObjects[0].Faces[0].normalAt(0,0)
While I can use an expression for the placement, I didn's succeed with the normal vector. Does anyone know how to do that?mario52 wrote: ↑Mon Jun 21, 2021 8:20 amCode: Select all
If you have an xy plane, then Placement.Rotation(Vector(0,0,1), NormalVector) will rotate it into the NormalVector direction.
Makes me think to this old topic : https://forum.freecadweb.org/viewtopic. ... 88#p325356
I failed to use this as an Expression for the normal vector, probably due to the function call. How is it possible - if at all?edwilliams16 wrote: ↑Mon Jun 21, 2021 8:56 am If you have an xy plane, then Placement.Rotation(Vector(0,0,1), NormalVector) will rotate it into the NormalVector direction.
Edit: Have to check openBrain's/GlouGlou's example.
Thanks for the trick with the line indicating the directionopenBrain wrote: ↑Mon Jun 21, 2021 9:16 am Makes me think to this old topic : https://forum.freecadweb.org/viewtopic. ... 88#p325356
As a simplification it is possible to use for the Base of the mirror a single expression: plane.Placement.Base.
