How to use inches in expression function
bananaphone
Post by bananaphone »
The ceil function isn't working as expected for me. It seems to have something to do with the unit.
For example, this expression
=ceil(40.1) correctly resolves to 41
However this resolves to some weird value:
=ceil(40.1 in) incorrectly resolves to 40.12 in
Ultimately I'm trying to round an expression up to the nearest 1/8th of an inch. Normally I could do that like this:
=ceil( someValue / (1/8) ) * (1/8)
But if someValue is in inches, it doesn't work correctly.
What am I missing here? Thanks in advance!
GeneFC
Re: How to use inches in expression function
Post by GeneFC »
It is clear that the ceiling is being calculated on the metric equivalent of the entry value.
Probably could be considered a bug, or at least a missing function.
FreeCAD does all internal calculations in metric, so a special function would be needed to calculate floor and ceiling for dimensions in other units.
Most linear and analytic functions work correctly in any units, but floor and ceiling are not linear nor analytic.
Gene
You may need something like
ceil(someValue*2.54 / (1/8)) * (1/8)
openBrain
Post by openBrain »
chrisb wrote: Mon Jun 21, 2021 6:15 am You may need something like
ceil(someValue*2.54 / (1/8) * (1/8))
One of the closing parentheses is misplaced. ;)
openBrain wrote: Mon Jun 21, 2021 7:39 am One of the closing parentheses is misplaced. ;)
Thanks for the hint. I have corrected my post above.
