Navigation cube quite small
Hi fellow Cadders.
Is it possible to increase the size slightly of the navigation cube, sometimes I try several times to say, pick the corner or occasionally rotate the cube?
The text on the cube is very small in normal use and almost unreadable.
So I resort to dragging the images/parts around with the mouse.
The attached image might give an idea of the issue, Icons are sized at 24px, It was OK in V0.18.
Your comments appreciated.
Thanks
OS: Windows 10 (10.0)
Version: 0.19.23546 (Git)
Hash: 6b017f9a16b15b0e628c8d874c4058442dee5548
Python version: 3.6.8
Qt version: 5.12.1
Thanks
Qt version: 5.12.1
- Cube size.JPG (63.64 KiB) Viewed 2352 times
Re: Navigation cube quite small
Here are the preferences of the navigation cube under Edit>Preferences:
If you install CubeMenu from addon manager, you will get much more adjustabilities
Many thanks 937.
I kept looking in preferences, but the cube size is not shown in my case (see screen snip)
However I downloaded the Cube Menu and was able to adjust the size from the settings.
Now looking good, as in screen snip .
Thanks again.
Thanks again.
- Cube size 2.JPG (230.64 KiB) Viewed 2272 times
Yes, 0.20dev (master) only. Added on 2021-03-09
https://github.com/FreeCAD/FreeCAD/comm ... 88c436a6d8
Greetings
user1234
Greetings
user1234
- Shalmeneser
Same problem here:
OS: Artix Linux (openbox)
Version: 0.20.26155 (Git) AppImage
Hash: 0926a4148bcff11249fd4f56bc30256102ffe105
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: Italian/Italy (it_IT)
Latest AppImage.
Plus Cube Menu will crash with an error.
I think that adding a simple font size box to the main preferences will be a more useful modification.
Regards
Carlo D.
Qt version: 5.12.9
OCC version: 7.5.3
Latest AppImage.
Regards
Carlo D.
- Various other stuffs.
Here you go Release_notes_0.20#User_interface
Regards / Viele Grüße
Max
Max
Here what, font size is not cited in any place, I have also an installation of realthunder's ls3 version and I have succeeded to change the font size,
using "Label" setting on the cube menu, but this setting is not in stock FC version.
The point is relying on an addon to make such simple change is not a clever way, this weird behaviour is also in latest 0.19 Appimage, but in past version everything will show correctly, I don't remember well but in 0.19 this behaviour was not present in former versions, I have noticed when I have updated 0.19 to the latest AppImage.
Maybe I have to set some font preferences elsewhere, maybe in the system Qt settings, but how to know what font size (and eventually what Qt font specification name) navigation cube is using?
EDIT: I have read some discussion speaking for a missing font, on some installations, but there were (or maybe I've not seen) the missing font name . Does anyone know something about it?
Regards
Carlo D.
