[Solved] Incorrect Dimensions?
KCStylus
Post by KCStylus »
So I am completely new to the program FreeCAD and to the entire CAD platform.
I currently am using ver. 19.2.
I am having issues with what might be the dimensions of both my sketches and objects. I set my preferences to use [inches and lbs ], so when I create a rectangle and make the dimensions of it 13in x 8in, I should be seeing something on the screen that resembles that size similar or accurate to a real life example. However, after I specify my measurements in the properties of the rectangle, the image I see looks like it doubled on only one axis and makes the object in question look off.
I'm not sure if this is a bug or if I didn't do something vital in the settings to make this error.
If anyone who knows CAD might have an idea please respond down below.
Thank you for your time.
hhassey
Re: Incorrect Dimensions?
Post by hhassey »
Works perfectly fine on my system.
Maybe you need to right click your object on the object tree and then ask for a recompute.
