OS: Debian GNU/Linux 10 (buster) (GNOME/default)
Version: 0.20.25116 (Git)
Hash: 267cb43a328aefeb674104bf5a3cf7cb7cc2076a
Python version: 3.7.3
Qt version: 5.11.3
Hello, I am trying to create a small building like this:
So I proceeded to create an array of objects(compounds with 3 solids each) then created a cutting object via Part Design.
And then used the boolean operation Difference or Cut of two shapes. (Array001 and Cutting Object) This is the unexpected result I get.
Am I doing something wrong? or is this a bug that should be reported?
I am attaching the file in case you want to confirm the behavior.
Cut of two shapes fails?
- cabina1.FCStd
- (218.17 KiB) Downloaded 16 times
Re: Cut of two shapes fails?
Set the fuse property for the Array001 to true, do the cut, add a CompoundFilter.
See the feature tree in this pic:
In the array properties change Fuse from False to True
Delete the body from the cutting object and extrude the sketch in Part workbench.
Now there is no unwanted mexture between Part design and Part workbench.
The Cut will now succeed
- thomas-neemann
i like the solution very much. now i also know what the compund filter can be used for. thanks
Thanks @drmarco but still is not really working, take a close look at the starting pieces, every panel of the array is made of 3 solids. The cut operations brings only one of them and two in some other places.
EDIT: I see what happened, the Polar Array has pieces intersecting themselves, this creates a problem, if i set it to only 31 pieces, they don't intersect and all goes smooth. Interesting is that the Part Check Geometry did not warn me about the self intersection of the Array
I still did not understand the use of the compound filter. Can you explain?
Thanks a lot
Thanks a lot
- thomas-neemann
You have to enable BOPCheck. That reveals lots of self intersections in Array001
The source of the still occurring problems is that the source of the array, Sip_Panel001, shows allready lots of errors on geometry check.
- thomas-neemann
