ShapeBinder still touched after recompute
3d_model_guy
Post by 3d_model_guy »
issue #4699
My goal is to create a box with protruding support for another body
1. create a Part, and under this part, I create two padded solids: inner and outer, where the volume of inner is slightly smaller than outer
2. create hexagon body.
3. create a clone of the hexagon body. In reality, I'll have multiple bodies with the same shape and have them placed around the box.
4. while active the 'inner' body, I create a shape binder to trace the hexagon shape of the "hexagon_clone" body.
5. create a sketch within the 'inner' body, and then using the "edge linked to external geometry (X)" tool to highlight the six vertices.
6. then use the polyline to connect each vertices to create a hexagon sketch.
7. pocket this sketch with 'inner' body.
8. select both 'inner' and 'outer' bodies, then make a 'cut' in Part workbench.
I now have a box with a hexagon support for the hexagon body like so:
In step 5, if I select the ShapeBinder, and make Trace Support "true", I'll get an error message saying "<App> Document.cpp(3527): test#ShapeBinder still touched after recompute"
However, the pocket appears to work just fine:
1. if I change the size of hexagon from step 2, the pocket will change as expected.
2. if I move the hexagon_clone around, the pocket follows its X-Y coordinates as expected.
The overall behavior is what I expected to be, but there's this error message of "<App> Document.cpp(3527): test#ShapeBinder still touched after recompute" , did I do something wrong, or could this be a bug?
Thanks.
Freecad version:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
test.FCStd
(46.32 KiB) Downloaded 54 times
Re: ShapeBinder still touched after recompute
I can't see what's going on, but I have simplified the model while keeping the issue with the touched ShapeBinder. So someone else may find it easier to find the culprit.
The issue vanishes if I set TraceSupport=false.
test_cb.FCStd
(12.52 KiB) Downloaded 52 times
The Placement of body "Inner" uses an expression. The problem vanishes if I set it to a fixed value. Looks like a buglet. Can someone please have a second look?
3d_model_guy
chrisb wrote: Mon Jun 21, 2021 11:21 pm The Placement of body "Inner" uses an expression. The problem vanishes if I set it to a fixed value. Looks like a buglet. Can someone please have a second look?
should I post it into bug tracker?
3d_model_guy wrote: Thu Jul 01, 2021 7:13 am should I post it into bug tracker?
I would have liked to see some more experts having a look, because it is rather cumbersome and I have the feeling that I missed something.
Bance wrote: pinged by pinger macro
drmacro wrote: pinged by pinger macro
Shalmeneser
Post by Shalmeneser »
Test_cb :
* Transform hexagon :
371.167 <App> Document.cpp(3527): test_cb_1_#ShapeBinder still touched after recompute
Shalmeneser wrote: Thu Jul 01, 2021 7:50 pm
Thanks for the confirmation
Please create a ticket and crosslink this discussion. And create a link from here to the ticket; you can use the bug tag for that.
3d_model_guy
here it is: issue #4699
TheMarkster
Post by TheMarkster »
You can just set the expression to constant = 0 and still have the same effect or am I missing something? Seems redundant to also have the expression to set the body's placement in addition to using the shapebinder.
Snip macro screenshot-1d4346.png (69.24 KiB) Viewed 2075 times
What does broken line in the dependency graph mean (as opposed to a solid line for the arrow)?
TheMarkster wrote: Sun Jul 04, 2021 12:57 am What does broken line in the dependency graph mean (as opposed to a solid line for the arrow)?
It is a reference caused by an expression.
