In TechDraw, middle mouse dragging deselects everything in terms of point selection for Insert Length Dimension
Insert Length Dimension doesn't allow post selection, so how do I do that ? It's already really tricky to select one single vertex as the target for the vertices is way too small (the actual pixels are used for the hit test, not a larger target like a circle centered on the vertex), and there is no helper to disambiguate close targets.
How to select two points far away from each others in TechDraw ?
Re: How to select two points far away from each others in TechDraw ?
You can change the size here
Can turn view frames off to hide vertices
- v1.jpg (294.19 KiB) Viewed 492 times
With Preferences->Display->Navigation->Zoom at cursor, you can easily zoom in and out to the right position.
Zoom to cursor does the trick:
- place mouse on first point - zoom in and select
- zoom out
- place mouse on second point - zoom in and select
Takes much longer to write up than to do it .
