Filleting compound curves
Vagulus
Post by Vagulus »
After recently changing to the new version of FC
OS: Windows 10 (10.0)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.4.0
Locale: English/New Zealand (en_NZ)
I decided to try the filleting tool where it wasn't working from a flat surface or a simple round end.
210624 Problem Fillets.png (46.16 KiB) Viewed 1080 times
(Get FCStd from https://1drv.ms/u/s!ArMxdUYEh9fKv30FFM7 ... c?e=o7Lr9m). I keep getting HTML Error when I try to attach it.)
To my delight, the arrowed fillets formed beautifully in the model but it stalled FC when exporting the STL file. When I removed the arrowed fillets the export was okay. Part --> Analyse geometry for errors shows problems with the arrowed fillets.
Has anyone else mentioned this problem? Is there an update/fix for this?
"It is much harder to simplify than to complicate."
Joseph Kimble
Re: Filleting compound curves
I can confirm: the generation of the STL doesn't end.
I found that the fillets cause BOPcheck errors though.
Vagulus
Post by Vagulus »
chrisb wrote: Thu Jun 24, 2021 7:28 am I found that the fillets cause BOPcheck errors though.
I gather BOP (here) stands for Boolean Operations. Well, this mere mortal does not understand what BOP Checks do in the process of creating fillets in a digital model but, for interest's sake, I de-activated them in FC and tried again (working on the principle that if the BOP Checks were the cause of the problem then, if I don't do them I don't have the problem - taking a leaf out of the President Trump and Covid-19 playbook ;) ). With this setting FC would not perform the filleting operation at the top (by the cylindrical ferrule) at all. Reactivating BOP Checks resulted in the same results as before - ferrules are modeled but FC goes into a loop when trying to create the STL file.
For a tie-rod end like this part having the fillets where arrowed would be a good feature so I have to ask, "Is there a work-around for this?"
Joseph Kimble
Vagulus wrote: Fri Jun 25, 2021 12:42 am "Is there a work-around for this?"
You can try a sweep.
Shalmeneser
Post by Shalmeneser »
File attachments are limited to 1MB in size.
Vagulus
Post by Vagulus »
Shalmeneser wrote: Fri Jun 25, 2021 9:38 am File attachments are limited to 1MB in size.
That needs fixing! :shock: We're two decades into the 21st Century. What can you do with 1MB?
Joseph Kimble
Vagulus wrote: Fri Jun 25, 2021 12:35 pm That needs fixing! :shock
Did everybody pay for the files?
Vagulus
Post by Vagulus »
chrisb wrote: Fri Jun 25, 2021 12:37 pm Did everybody pay for the files?
Who does pay for the files?
Joseph Kimble
Vagulus wrote: Fri Jun 25, 2021 10:16 pm Who does pay for the files?
The webspace is not for free. Jürgen Riegel, one of the founders, still pays for it.
Vagulus
Post by Vagulus »
chrisb wrote: Fri Jun 25, 2021 10:32 pm The webspace is not for free.
If there is a contributors' list I'll throw in my Widow's Mite.
If there ain't, why ain't there?
Joseph Kimble
