Filleting compound curves
After recently changing to the new version of FC
OS: Windows 10 (10.0)
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: English/New Zealand (en_NZ)
I decided to try the filleting tool where it wasn't working from a flat surface or a simple round end. (Get FCStd from https://1drv.ms/u/s!ArMxdUYEh9fKv30FFM7 ... c?e=o7Lr9m). I keep getting HTML Error when I try to attach it.)
To my delight, the arrowed fillets formed beautifully in the model but it stalled FC when exporting the STL file. When I removed the arrowed fillets the export was okay. Part --> Analyse geometry for errors shows problems with the arrowed fillets.
Has anyone else mentioned this problem? Is there an update/fix for this?
Qt version: 5.12.9
OCC version: 7.4.0
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: Filleting compound curves
I can confirm: the generation of the STL doesn't end.
I found that the fillets cause BOPcheck errors though.
I gather BOP (here) stands for Boolean Operations. Well, this mere mortal does not understand what BOP Checks do in the process of creating fillets in a digital model but, for interest's sake, I de-activated them in FC and tried again (working on the principle that if the BOP Checks were the cause of the problem then, if I don't do them I don't have the problem - taking a leaf out of the President Trump and Covid-19 playbook ). With this setting FC would not perform the filleting operation at the top (by the cylindrical ferrule) at all. Reactivating BOP Checks resulted in the same results as before - ferrules are modeled but FC goes into a loop when trying to create the STL file.
For a tie-rod end like this part having the fillets where arrowed would be a good feature so I have to ask, "Is there a work-around for this?"
Joseph Kimble
Joseph Kimble
- Shalmeneser
File attachments are limited to 1MB in size.I keep getting HTML Error when I try to attach it.
That needs fixing! We're two decades into the 21st Century. What can you do with 1MB?
Joseph Kimble
Joseph Kimble
Did everybody pay for the files?
Who does pay for the files?
Joseph Kimble
Joseph Kimble
The webspace is not for free. Jürgen Riegel, one of the founders, still pays for it.
If there is a contributors' list I'll throw in my Widow's Mite.
If there ain't, why ain't there?
Joseph Kimble
Joseph Kimble
