[Fixed] "Polar Pattern" compatibility between 0.19 and 0.20
Good evening,
With some members of the French forum, we realized a problem between
the files created with version 0.19 and 0.20 containing the polar pattern.
Example:
I create a new file and Body with version 0.19 containing a polar pattern with 10 repeats.
I open this file with version 0.20, it is displayed correctly, but the repeat value is set to "3" instead of "10" .
If I refresh the model, the repeat is changed to 3.
The problem is the same with a file created with version 0.20
opened with version 0.19 the number of repetitions of the polar pattern is still 3
I didn't find any info on the forum about this, is it something known?
my 0.19 version :
OS: Linux Mint 20.1 (XFCE/xfce)
Version: 0.19.
Branch: unknown
Hash: 9e3b630bbfb6807e93eeffb655e6c20f218644fc
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
Locale: French/France (fr_FR)
my 0.20 version :
Version: 0.20.25157 (Git) AppImage
Hash: 257cdd8f423f1530b8df6f53e242de629fee4e85
Python version: 3.9.5
Qt version: 5.12.9
OCC version: 7.5.2
Example:
my 0.19 version :
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.1
my 0.20 version :
Qt version: 5.12.9
OCC version: 7.5.2
Re: "Polar Pattern" compatibility between 0.19 and 0.20
Would've been nice to add an example directly Therefore I've created one. But I'm not able to reproduce what you've described. My example looks fine in both versions.
I've used this versions:
edit
added my example
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Version: 0.20.25131 (Git) AppImage
Hash: 7c519689f0d5ea78fb3292be36a857d283c05507
Qt version: 5.12.9
OCC version: 7.5.2
edit
added my example
- PD_Polar_Pattern_10_times_v0.19.FCStd
- (43.22 KiB) Downloaded 35 times
Regards / Viele Grüße
Max
Max
- Shalmeneser
If I open this file in 0.20.25313, then PolarPattern give 3 occurrences.
OS: Linux Mint 19.3 (MATE/mate)
Qt version: 5.12.9
OCC version: 7.5.2
- Snip macro screenshot-934aee.png (64.27 KiB) Viewed 1659 times
- bouton(3).FCStd
- (46.92 KiB) Downloaded 29 times
Like Shalmeneser, if I open your file with version 0.20 the display is correct,
but the number of occurrences in the polar pattern is set to 3
with 0.19
With 0.20
with 0.19
With 0.20
Ups, I've forgot to have a look at the polar pattern setting and to recompute
I can confirm, looks like a bug to me. This is how it looks after a recompute.
Max
Max
Confirmed.Shalmeneser wrote: ↑Tue Jun 29, 2021 9:11 pm If I open this file in 0.20.25313, then PolarPattern give 3 occurrences.
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Edit: I looked directly at the file. In Document.xml it has the correct number of 10 Occurrences.
The bug also applies to LinearPattern so I believe the regression was caused by git commit 7f1b47d
uwestoehr wrote: pinged by pinger macro
Max
Max
Why do you think so? This commit only fixed the bug that one could e.g. enter zero occurrences.Syres wrote: ↑Wed Jun 30, 2021 7:04 am The bug also applies to LinearPattern so I believe the regression was caused by git commit 7f1b47d
As you can see in the PR, the
ADD_PROPERTY(Occurrences, (3));
However, this fixed value seems to cause the bug. When I find time, i can have a look why this happens.
In the simple debugging I carried out, it seems the PolarPattern::handleChangedPropertyType isn't being triggered when the user opens a 0.19 file in 0.20 so the number of Occurrences isn't being read in from the file. Maybe my debugging skills aren't up to scratch but that's where I concentrated my investigation.
