I played with this a bit, and it appears that a change in property type may be the cause.
I created a simple model with 8 repeats and saved in both version 0.19 (release) and version 0.20 (25065). As noted above, neither file opened correctly in the other FC version. Here are the relevant portions of the document.xml files.
- FC Version 0.19.PNG (1.82 KiB) Viewed 1719 times
- FC Version 0.20.PNG (1.85 KiB) Viewed 1719 times
I am not even a slight bit conversant with C++, but I would guess that each FC version is looking for a variable that does not exist because it has the wrong property type.
Gene
