Regression in PartDesign mirror
Re: Regression in PartDesign mirror
I will retest as soon as the next precompiled version is available.
Founder
Post by wmayer »
After doing a manual bisect I could track it down to the following four subsequent commits:
git commit 03da9d350: This shows a very obscure behaviour because the tip of the body is either empty or it shows the inverted and mirrored shape
git commit fecf9c2e84: Shows still the same behaviour
git commit 8453d4151: This fixes the above oddity but when mirroring a pad then the gap of the pocket is filled. And if mirroring the pocket then it's not transformed correctly.
git commit 3131b97aa: The log message says it fixes a bug in the preview but for me it doesn't make any difference.
It needs some further testing to figure what exactly makes it to behave incorrectly.
wmayer wrote: Mon Sep 20, 2021 8:22 am It needs some further testing to figure what exactly makes it to behave incorrectly.
How can we help?
Founder
Post by wmayer »
chrisb wrote: Mon Sep 20, 2021 8:42 am
How can we help?
I have tested it with:
OS: Ubuntu 18.04.5 LTS (XFCE/xubuntu)
Version: 0.20.24419 (Git)
Build type: Unknown
Branch: (HEAD losgelöst bei 3131b97aa8)
Hash: 3131b97aa88736ac628428a8ceb025d9b7a8a965
Python version: 3.6.9
Qt version: 5.9.5
Some of you said it's working with newer OCCT versions. So, I would like to hear whether it works with OCCT 7.5.
Founder
Post by wmayer »
I have an older build from April that has included the regression and it uses OCCT 7.5.0 and the bug is also there. Now when looking at the changes in PD since April I cannot see anything that fixes the transform features. So, I think the bug must be still present in current master independent of the OCCT version.
Version: 0.20.24758 (Git)
Build type: Unknown
Hash: b7aee7bfa101e37e0211aaa8ef36e318f3d797c1
Qt version: 5.9.5
OCC version: 7.5.0.beta
Founder
Post by wmayer »
Here the forum thread where the pattern stuff was discussed: https://forum.freecadweb.org/viewtopic.php?f=19&t=55860
Founder
Post by wmayer »
Here is a script that is supposed to demonstrate the issue and avoids that users do slightly different things:
import FreeCAD as App
doc = App.newDocument("Mirror_Pattern")
body = doc.addObject('PartDesign::Body','Body')
sketch = body.newObject('Sketcher::SketchObject','Sketch')
sketch.Support = (doc.getObject('XY_Plane'),[''])
sketch.MapMode = 'FlatFace'
geoList = []
geoList.append(Part.LineSegment(App.Vector(0.0, 30, 0), App.Vector(100, 30, 0)))
geoList.append(Part.LineSegment(App.Vector(100, 30, 0), App.Vector(100,-30, 0)))
geoList.append(Part.LineSegment(App.Vector(100,-30, 0), App.Vector(0.0,-30, 0)))
geoList.append(Part.LineSegment(App.Vector(0.0,-30, 0), App.Vector(0.0, 30, 0)))
sketch.addGeometry(geoList,False)
conList = []
conList.append(Sketcher.Constraint('Coincident',0,2,1,1))
conList.append(Sketcher.Constraint('Coincident',1,2,2,1))
conList.append(Sketcher.Constraint('Coincident',2,2,3,1))
conList.append(Sketcher.Constraint('Coincident',3,2,0,1))
conList.append(Sketcher.Constraint('Horizontal',0))
conList.append(Sketcher.Constraint('Horizontal',2))
conList.append(Sketcher.Constraint('Vertical',1))
conList.append(Sketcher.Constraint('Vertical',3))
sketch.addConstraint(conList)
sketch.addConstraint(Sketcher.Constraint('PointOnObject',0,1,-2))
doc.recompute()
pad = body.newObject('PartDesign::Pad','Pad')
sketch.Visibility = False
pad.Profile = sketch
pad.Length = 10.0
pad.Length2 = 100.000000
pad.UseCustomVector = 0
pad.Direction = (0, 0, 1)
pad.AlongSketchNormal = 1
pad.Type = 0
pad.UpToFace = None
pad.Reversed = 0
pad.Midplane = 0
pad.Offset = 0
doc.recompute()
print (pad.Shape.Volume == 60000)
sketch1 = body.newObject('Sketcher::SketchObject','Sketch001')
sketch1.Support = (pad,['Face3',])
sketch1.MapMode = 'FlatFace'
geoList = []
geoList.append(Part.LineSegment(App.Vector(-10, 25, 0), App.Vector( 20, 25, 0)))
geoList.append(Part.LineSegment(App.Vector( 20, 25, 0), App.Vector( 20,-12, 0)))
geoList.append(Part.LineSegment(App.Vector( 20,-12, 0), App.Vector(-10,-12, 0)))
geoList.append(Part.LineSegment(App.Vector(-10,-12, 0), App.Vector(-10, 25, 0)))
sketch1.addGeometry(geoList,False)
conList = []
sketch1.addConstraint(conList)
doc.recompute()
pocket = body.newObject('PartDesign::Pocket','Pocket')
sketch1.Visibility = False
pad.Visibility = False
pocket.Profile = sketch1
pocket.Length = 20.000000
pocket.Length2 = 100.000000
pocket.Type = 0
pocket.UpToFace = None
pocket.Reversed = 0
pocket.Midplane = 0
pocket.Offset = 0
doc.recompute()
print (pocket.Shape.Volume==56000)
mirror = body.newObject('PartDesign::Mirrored','Mirrored')
mirror.Originals = [pad,]
mirror.MirrorPlane = (pad, ['Face4'])
body.Tip = mirror
doc.recompute()
print (mirror.Shape.Volume) # returns 120000.0 but should be 116000.0
At the end it prints a volume of 120000 of the mirror feature instead of the expected 116000 (=60000 + 56000)
uwestoehr
Post by uwestoehr »
wmayer wrote: Mon Sep 20, 2021 11:20 am Here is a script that is supposed to demonstrate the issue and avoids that users do slightly different things:
I can confirm the bug is still inn today's master. The bug can be reproduced using the script and also the initial example file of this thread.
OS: Windows 10 Version 2009
Version: 0.20.25778 (Git)
Hash: 7f772ba227aa5fcb778f0e6991f167d080ebd03f
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
