Regression in PartDesign mirror
When mirroring not the latest, but a former pad, then not only the mirror is filled, but also the original again. Thus all pockets are lost.
I have added two bodies, one made with sketch based features, the other made from primitives. Both show the error.
See Pad and pocket at the top, and the mirror of the pad at the bottom: Error in this version:
OS: macOS 10.16
Version: 0.20.25157 (Git)
Hash: 257cdd8f423f1530b8df6f53e242de629fee4e85
Python version: 3.9.5
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
This is how it should look like: Works in this version:
OS: macOS 10.16
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.8
Qt version: 5.12.5
OCC version: 7.4.0
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
OS: macOS 10.16
Qt version: 5.12.5
OCC version: 7.4.0
- mirror_fills_pocket.FCStd
- (26.94 KiB) Downloaded 49 times
- Shalmeneser
Re: Regression in PartDesign mirror
You need to select Pad + Pocket (in this order) to do the symmetry of everything.
(My understanding : the selection is copied at the 1st place and at the symmetrical place.)
Confirmed. The results looks good if you're setting the tip to Pad/ Box before the mirroring.
And it's working as it should without changing the tip with this version:
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25131 (Git) AppImage
Hash: 7c519689f0d5ea78fb3292be36a857d283c05507
Qt version: 5.12.9
OCC version: 7.5.2
Version: 0.19.24276 (Git) AppImage
Branch: (HEAD detached at 0.19.1)
Qt version: 5.12.9
OCC version: 7.4.0
That's not what chrisb is describing here. Have a look at his "this is how it should look like" screenshot in the initial post.Shalmeneser wrote: ↑Fri Jul 02, 2021 9:29 pm You need to select Pad + Pocket (in this order) to do the symmetry of everything.
Regards / Viele Grüße
Max
Max
+1, this is the behavior always and is correct.Shalmeneser wrote: ↑Fri Jul 02, 2021 9:29 pm You need to select Pad + Pocket (in this order) to do the symmetry of everything.
Greetings
user1234
What do you mean by "always"? That's not how it used to be, and there are usecases where not everything should be mirrored. I agree that it could be useful to have pattern/mirror functions which operate on "everything up to the selected feature", but this case is different. A mirror should add a mirror and nothing else.
This regression would break quite some existing models.
Oh, now i see. Sorry, my fault. The small edge is filled. Yes, that is a regression. Maybe related to the this https://forum.freecadweb.org/viewtopic.php?t=57658?
Greetings
user1234
Greetings
user1234
I'm afraid that this case is more complicated, because the linked issue occurred only with primitives. Here it happens on sketch based features as well.user1234 wrote: ↑Sat Jul 03, 2021 12:37 amMaybe related to the this https://forum.freecadweb.org/viewtopic.php?t=57658?
In this case it could be a solution, but it's a different use case, because it mirrors the last feature. Imagine a model with fillets or cutting things off around the first box (which simulates a "common" operation). That would require a complete rework of the model.
- Shalmeneser
Symmetry of the pad keeps the hole in v0.19.
Symmetry of the pad doesn't keep the hole in v0.20.
OS: Linux Mint 19.3 (MATE/mate)
Qt version: 5.12.9
OCC version: 7.4.0
Locale: French/France (fr_FR)
Qt version: 5.12.9
OCC version: 7.5.2
Thanks for all the confirmations! Is here anyone around having the same version with OCC 7.5.2 and an older version?
