Regression in PartDesign mirror
user1234
Re: Regression in PartDesign mirror
Post by user1234 »
works on:
OS: Debian GNU/Linux 11 (bullseye) (X-Cinnamon/lightdm-xsession)
Version: 0.20.Unknown --> 0.20.24409
Build type: Unknown
Python version: 3.9.2
Qt version: 5.15.2
OCC version: 7.5.1
So the issue is between 24553 - 24409
Greetings
user1234
user1234
Post by user1234 »
It seems it is between 24416 and 24419. Here are worked on the transformation on mirrors in mirrors in PartDesign.
Greetings
user1234
user1234
Post by user1234 »
src/Mod/PartDesign/App/FeatureTransformed.cpp
between Line 299 and 300:
++t; // Skip first transformation, which is always the identity transformation
The line as removed. When i add them it works. The question is, if i add them if any other regression will appear. But today my time is over.
Greetings
user1234
chennes wrote: Mon Jul 05, 2021 2:00 pm What revision do you want me to test?
Sorry, with all these versions flying around things became rather obscured than clear. I have tested with the latest precompiled version and it still shows the issue. It would be kind if you look at the current master. The issue is described in the first post of this topic: Load the file
mirror_fills_pocket.FCStd and recompute it. It should show the small cubic cutout, but instead it is filled.
OS: macOS 10.16
Version: 0.20.25176 (Git)
Hash: 909dfa7036f9fd36bbd3acee2a5dee161d2819fb
Python version: 3.9.5
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Edit: Had the tab open for quite some time and thus missed user1234's very helpful investigations.
uwestoehr
Post by uwestoehr »
The bug should now be fixed with commits
https://github.com/FreeCAD/FreeCAD/commit/9fe1f56824
and
https://github.com/FreeCAD/FreeCAD/comm ... 54135ccfe2
For those interested in the technical details of the bug, see https://forum.freecadweb.org/viewtopic.php?f=10&t=60054
Thanks!
uwestoehr
Post by uwestoehr »
chrisb wrote: Wed Sep 15, 2021 5:52 pmThanks!
Can you please mark this thread therefore as "[fixed]"
Founder
Post by wmayer »
uwestoehr wrote: Wed Sep 15, 2021 2:56 pm The bug should now be fixed with commits
and
This has nothing to do with the other bug. The other bug was only about loading an older project where certain renamed or retyped properties couldn't be read-in.
Founder
Post by wmayer »
If not yet done please open a bug report and post its ID here.
I can reproduce the problem also with OCC 7.3.0
user1234
Post by user1234 »
I can not reproduce it anymore.
Version: 0.20.25723 (Git)
Hash: 9fe1f568246dd63573e6d12aaffbcd8ebaf7cf51
Qt version: 5.15.2
OCC version: 7.5.3
But it is hard to believe that it is OCCT related.
Greetings
user1234
