All the lines in my sketch are no longer attached.
I can just grab a line and move it and it's not attached to the rest of the piece. This is not how it was before.
Is there a way to reattach all the lines together? I'm really struggling with this.
Thanks!
Re: All the lines in my sketch are no longer attached.
Please have a look at the big red banner at the top and provide the missing information.
Regarding the fix of the current state, have a look at Sketcher_ConstrainCoincident.
Regards / Viele Grüße
Max
Max
- Shalmeneser
At some occasions, all my constrains dissapear and I don't know why.
You have to reconstrain all your sketch.
To constrain point over point :
* select points with box selection (from the left to the right).
* contrain them (shortcut C).
To constrain line horizontally :
* select a part of the line with box selection (from the right to the left).
* contrain them (shortcut H).
The same vertically (V).
Use the Sketch validation tool to find and repair missing coincidences.
Oops I forgot. That link was useful. I didn't realize the direction when selecting with the mouse mattered.
Thanks!
This tool is a god send. Thanks, that worked beautifully! Is it possible to report this issue (if it hasn't already been reported). It's kind of a pain because, although I was able to repair the missing conincidences, all my dimensions I had to re-add.
Can you reproduce it?bassamanator wrote: ↑Tue Jul 06, 2021 10:54 pm This tool is a god send. Thanks, that worked beautifully! Is it possible to report this issue (if it hasn't already been reported). It's kind of a pain because, although I was able to repair the missing conincidences, all my dimensions I had to re-add.
Sorry, reproduce what exactly? I was able to reproduce the sketch, yes.chrisb wrote: ↑Wed Jul 07, 2021 12:00 amCan you reproduce it?bassamanator wrote: ↑Tue Jul 06, 2021 10:54 pm This tool is a god send. Thanks, that worked beautifully! Is it possible to report this issue (if it hasn't already been reported). It's kind of a pain because, although I was able to repair the missing conincidences, all my dimensions I had to re-add.
In your first post you say ...bassamanator wrote: ↑Fri Jul 30, 2021 5:51 am Sorry, reproduce what exactly? I was able to reproduce the sketch, yes.
... so I concluded that you had a sketch with lots of constraints. And all of a sudden these constraints vanished. My question meant: can you reproduce this "all of a sudden"?
I don't think I can reproduce this 'all of a sudden', the reason being that it was a file that I had not touched in a long time, and when I finally got back to it, the constraints were gone.
Excuse the late reply.
Do you have a backup of that file? When the problem occurred did you write the problem file with a new name to preserve your original? If you have the original unmodified file please attach it here for investigation.bassamanator wrote: ↑Mon Feb 21, 2022 1:02 am when I finally got back to it, the constraints were gone
