FCInfo Macro
Vincent B
Re: FCInfo Macro
Post by Vincent B »
mario52 wrote: Sat Jun 16, 2018 5:10 pm just cause HighDP, here the solution by UR_
Its working, but its a shame to not run Freecad in Hi Res.
Ca marche, mais c'est dommage de ne pas avoir Freecad en haute résolution. :roll:
mario52
Re: FCInfo Macro
Post by mario52 »
hi
GlouGlou wrote: Sat Jun 16, 2018 5:25 pm Its working, but its a shame to not run Freecad in Hi Res.
yes because of a macro (Qt)
oui a cause d'une macro (Qt), je vais encore chercher
mario
easyw-fc
Re: FCInfo Macro
Post by easyw-fc »
mario52 wrote: Sat Jun 16, 2018 8:02 pm yes because of a macro (Qt)
this is an annoying issue also with my macros... I moved almost everything on buttons without a text caption, but in many cases it is not possible to avoid text, and there the issue will raise...
We would need a way to adapt the text size to the room available in the text container...
Please post here if you find a way to solve this :D
Maurice
ulrich1a
Re: FCInfo Macro
Post by ulrich1a »
easyw-fc wrote: Sat Jun 16, 2018 8:29 pm We would need a way to adapt the text size to the room available in the text container...
I found the following two webpage regarding the topic: https://www.charlesodale.com/setting-qt ... alization/
So does it help to fix the fontsize with a statement like the following, where "w" is the widget?
font = w.font()
font.setPixelSize(12)
w.setFont(font)
This would go the other way around and should fix the fontsize to the current layout. I do not have a high resolution display, so I can not test.
Ulrich
mario52
Re: FCInfo Macro
Post by mario52 »
hi
in my macro i use
        self.fontGlobal_08 = QtGui.QFont()
        self.fontGlobal_08.setFamily("Arial")
        self.fontGlobal_08.setPointSize(8.0)    # line 1124
testing request modify setPointSize(8.0) in setPixelSize(11) (line 1124) and restore the HighDPI display to see
mario
Vincent B
Re: FCInfo Macro
Post by Vincent B »
After change, this is what i got. :roll:
My res is 1680x1050
Vincent B
Re: FCInfo Macro
Post by Vincent B »
easyw-fc wrote: Sat Jun 16, 2018 8:29 pm this is an annoying issue also with my macros...
Can use it anyway.
mario52
Re: FCInfo Macro
Post by mario52 »
hi
my result with setPointSize(8) and PPP 150% (manual adjustment: "Paramètres avancés de mise à l'échelle")
here with setPixelSize(11) and PPP 150% (manual adjustment) the title is large (same above, can be remove the bold text !!) and in the lineEdit is good
mario
mario52
Re: FCInfo Macro
Post by mario52 »
hi
want to test this version (without bold and with setPixelSize(11))
unzip the file
FCInfo_For_Testng_PPP.zip
(28.58 KiB) Downloaded 55 times
mario
UR_
Re: FCInfo Macro
Post by UR_ »
Comparison of widget sizes
on a 2736 x 1824 pixel display
Windows user defined scaling 175%
screenshot FCInfo.png (69.85 KiB) Viewed 2402 times
As you can see, reducing font size doesn't solve the problem.
This only reverts settings, user defined while installing windows.
Better read out user defined scaling and insert this factor to all code lines containing hardcoded pixel values. Therefore dialog is scaled up and font will fit.
