FCInfo Macro
mario52
Re: FCInfo Macro
Post by mario52 »
hi
100%
PySide.QtCore.QSize(1680, 1010)
96
96
125%
PySide.QtCore.QSize(1344, 800)
96
96
150%
PySide.QtCore.QSize(1120, 660)
96
96
175%
PySide.QtCore.QSize(960, 560)
96
96
ps: the dpi is not modified ! and the text in the window is normal
i give the definition (1680, 1010) but the screen is modified in 1344, 800 (125%) or 1120, 660 (150%) or 960, 560 (175%) !!
here 175%
mario
hammax
Re: FCInfo Macro
Post by hammax »
… using the FCInfoMacro for determination of the center of mass for a sailboat hull with a heeling angle,
needing the lifting force of the displaced water volume.
I get also an item with "center of form" ???? What's its use and meaning?
Edit: I suppose this means BoundingBox
mario52
Re: FCInfo Macro
Post by mario52 »
hi
yes BoundingBox center
in the comboView FCPointBBCenter read FCPointBoundBoxCenter
            sel = FreeCADGui.Selection.getSelection()
            boundBox_ = sel[0].Shape.BoundBox
             # centre de la forme
            try:
                boundBoxCenterX = boundBox_.Center[0]
                boundBoxCenterY = boundBox_.Center[1]
                boundBoxCenterZ = boundBox_.Center[2]
            except Exception:
                boundBoxCenterX = 0.0
                boundBoxCenterY = 0.0
                boundBoxCenterZ = 0.0
maybe modify Forme to BounBox line 2442
        self.label_13.setText("Forme")
also Macro_CenterOfMass for many object selected
mario
freecad-heini-1
Re: FCInfo Macro
Post by freecad-heini-1 »
I had the problem that fcinfo slows down my system after it was run. In particular, selecting multiple faces, e.g. to copy, takes a long time, even measuring distances or angles, with the Part Workbench measurement tools. Maybe it's me, because I'm not sure if I installed the fcinfo macro correctly.
I copied the newest version from here.
https://gist.github.com/mario52a/8d40ab6c018c2bde678f
I have created a new macro, assigned a name, e.g. fcinfo1.21, copied the whole text of the macro into it, closed it and saved it.
The new macro doesn't slow down my system anymore, but it is in French. Where can I find a current fcinfo macro in english and how is the right way to install it?
mario52
Re: FCInfo Macro
Post by mario52 »
hi
freecad-heini-1 wrote: Mon May 27, 2019 10:51 am I have created a new macro, assigned a name, e.g. fcinfo1.21, copied the whole text of the macro into it, closed it and saved it.
the macro Fr , En , It are identical only the text change , are you sure to work with other version on the precedent macro and same object as before ?
i compare 2 macros Fr and En with a text editor (Notepad++) and the code is equal
mario
freecad-heini-1
Re: FCInfo Macro
It's this macro:
__title__    = "FCInfo"
__author__   = "Mario52"
__url__      = "http://www.freecadweb.org/index-en.html"
__version__  = "01.20"
__date__     = "29/01/2018"
mario52
Re: FCInfo Macro
Post by mario52 »
freecad-heini-1 wrote: Mon May 27, 2019 2:10 pm Code: Select all
hi
it is this macro that works very well ?
mario
freecad-heini-1
Re: FCInfo Macro
mario52 wrote: Mon May 27, 2019 2:20 pm
hi
mario
No. That's the macro that slow down Freecad.
mario52
Re: FCInfo Macro
Post by mario52 »
hi
freecad-heini-1 wrote: Mon May 27, 2019 10:51 am I copied the newest version from here.
then this link is the latest version in English
1.21 French version
1.21 English version (as your link)
mario
freecad-heini-1
Re: FCInfo Macro
Thank you very much Mario.
