[bug 4705] [Draft] toolbar is active for all workbenches
uwestoehr
Postby uwestoehr » Thu Jul 15, 2021 3:50 pm
I encountered a bug (also in FreeCAD 0.19) that this toolbar is always displayed and active:
Even, when I set the Workbench to "None", I see this toolbar.
Whenever I click on a button of this toolbar I get this error:
File "D:\FreeCAD-build\Mod\Draft\DraftGui.py", line 1924, in selectplane
FreeCADGui.runCommand("Draft_SelectPlane")
Base.FreeCADError: No such command 'Draft_SelectPlane'
Can other reproduce this? It seems one just has to be at least once in the Draft workbench to get this toolbar.
OS: Windows 10 Version 2009
Version: 0.20.25275 (Git)
Hash: f20e29a04c1a539217eb7ef081b94d9526823e15
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
domad
Re: [Draft] toolbar is active for all workbenches
Postby domad » Thu Jul 15, 2021 6:04 pm
uwestoehr wrote: Thu Jul 15, 2021 3:50 pm ............
Hi uwestoehr, good evening to the Community!
OS: Windows 8 (6.2)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: Italian/Italy (it_IT)
It does not happen with the 0.20, but various errors are reported during use (irrelevant to the result, but which still deserve to be investigated).
The bar is present in Draft and Arch (I suppose also in BIM) not present in the other Wb.
Here what happens when using https://forum.freecadweb.org/viewtopic.php?f=3&t=60088
I don't know with 0.19, as I have long since replaced it with 0.20.
Roy_043
Postby Roy_043 » Thu Jul 15, 2021 6:35 pm
I can confirm this:
It depends on the V0.20 version. It happens in the 'Conda' versions, but not in the 'LPv' versions.
And it only happens if Draft was the active WB when FreeCAD was last closed.
Conda versions where the problem occurs:
FreeCAD_weekly-builds-25065-Win-Conda_vc14.x-x86_64.7z
FreeCAD_weekly-builds-25220-Win-Conda_vc14.x-x86_64.7z
LPv version where the problem does not occur:
FreeCAD_0.20.25065_Win-LPv12.5.4_vc17.x-x86-64.7z
Details of the last Conda version:
OS: Windows 8.1 (6.3)
Qt version: 5.12.9
OCC version: 7.5.2
uwestoehr
Postby uwestoehr » Thu Jul 15, 2021 7:15 pm
I get this bug also with the latest FC 0.19.2 release we offer at our website for Windows:
https://www.freecadweb.org/downloads.php
The problem occurs when you go to the draft WB, then close FreeCAD. From that one the toolbar is always present and active, no matter what toolbar you are in. I can also not find a way to disable it.
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Shalmeneser
Postby Shalmeneser » Thu Jul 15, 2021 7:23 pm
I have encountered this problem. I don't remember the solution.
Roy_043
Postby Roy_043 » Thu Jul 15, 2021 7:57 pm
In my experience the toolbar, actually called the Draft Tray, disappears when you load Draft and then another WB.
  1. Make sure the startup WB is Part.
  2. Activate the Darft WB.
  3. Exit FC.
  4. Restart FC.
  5. The toolbar is now visible although the active WB is Part.
  6. Switch to Draft.
  7. Switch to Part again.
  8. Result: the toolbar is gone.
uwestoehr
Postby uwestoehr » Thu Jul 15, 2021 8:08 pm
Roy_043 wrote: Thu Jul 15, 2021 7:57 pm In my experience the toolbar, actually called the Draft Tray, disappears when you load Draft and then another WB.
Many thanks! So there is at least a workaround.
However, it is a bug that should be fixed and I will make a bug report.
uwestoehr
Re: [bug 4705] [Draft] toolbar is active for all workbenches
Postby uwestoehr » Fri Jul 16, 2021 12:08 pm
I reported the bug now as issue #4705.
marioalexis
Postby marioalexis » Tue Jul 20, 2021 4:23 am
The same was reported last year, but about AppImage on Linux: https://forum.freecadweb.org/viewtopic.php?f=23&t=52667
I guess it's still happens today. Seems to be some kind of problem with Conda packages (AppImage also uses Conda).
There is another report of "suspicious behavior" in Draft workbench. I asked the reporters if they also use versions based on Conda.
Maybe @looo can help.
openBrain
Postby openBrain » Tue Jul 20, 2021 6:20 am
Could one run FreeCAD from console and check for weird error/log report at FreeCAD opening/closing?
EDIT : I tried to reproduce with 0.19 AppImage (FreeCAD_0.19-24291-Linux-Conda_glibc2.12-x86_64.AppImage) but I wasn't able to.
