[bug 4705] [Draft] toolbar is active for all workbenches
uwestoehr
Re: [bug 4705] [Draft] toolbar is active for all workbenches
Post by uwestoehr »
marioalexis wrote: Tue Jul 20, 2021 4:23 am I guess it's still happens today. Seems to be some kind of problem with Conda packages (AppImage also uses Conda).
I don't use Conda, I compile FreeCAD by myself using the LibPack. So the reason must be something else.
Roy_043
Post by Roy_043 »
It is an important clue. The issue seems to be compilation related.
The problem occurs in this version (and in other "Conda" versions):
FreeCAD_weekly-builds-25220-Win-Conda_vc14.x-x86_64.7z
OS: Windows 8.1 (6.3)
Version: 0.20.25220 (Git)
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.8.10
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.2
But not in this version (or in other "LPv" versions):
FreeCAD_0.20.25306_Win-LPv12.5.4_vc17.x-x86-64.7z
OS: Windows 8.1 Version 6.3 (Build 9600)
Version: 0.20.25306 (Git)
Hash: 5f5b3d9b67136edda1f6738f1a83154990f7839d
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
uwestoehr
Post by uwestoehr »
Roy_043 wrote: Sun Jul 25, 2021 7:37 am But not in this version (or in other "LPv" versions):
Interesting, because I use LibPack 12.5.4 too:
OS: Windows 10 Version 2009
Version: 0.20.25327 (Git)
Hash: 1cc9c88be19d582540620d5c69d00fa30f6ef805
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I compiled now everything new from scratch but the issue persists. The only difference I see is that you use Windows 8.1 but I cannot imagine that this makes the difference.
Roy_043
Post by Roy_043 »
I do not know anything about compiling, but maybe this helps?:
https://forum.freecadweb.org/viewtopic. ... 96#p507306
