Bug: Fillet breaking surface
Vincent B
Re: Bug: Fillet breaking surface
Post by Vincent B »
Part's fillet screw up too with an 4 edges crossing. Probably because OCCT. :roll:
Cekuhnen
Post by Cekuhnen »
GlouGlou
My previous comment about design WB is incorrect indeed
I did not notice that the seam was changed
Not an excuse - but it was late at night
I assumed OCCT as a very known Kernel could handle this but as it shows it cannot
Also the refine command does not remove the seam.
Good to know for reference and easy to work around by pre rounding in the sketch.
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Cekuhnen
Post by Cekuhnen »
GlouGlou wrote: Fri Jul 16, 2021 8:03 pm Part's fillet screw up too with an 4 edges crossing. Probably because OCCT. :roll:
Extruding a filleted sketch makes it all work.
Screen Shot 2021-07-17 at 6.02.24 PM.png (57.59 KiB) Viewed 792 times
Designer | Faculty
Shalmeneser
Post by Shalmeneser »
File ?
Cekuhnen
Post by Cekuhnen »
I will share the full file when it is done
here is a screen recording
https://drive.google.com/file/d/10ZNRL4 ... PbJuY/view
the rim sweep ( thick lip) i will add at the end - this command is slowing down FC significantly
Designer | Faculty
Forthman
Post by Forthman »
good tip for the spout, I take note! :idea: :D
and yes, the rim sweep turns Freecad into a snail :shock:
Capture d’écran_2021-07-18_10-28-25.png (87.71 KiB) Viewed 724 times
Cekuhnen
Post by Cekuhnen »
yeah it is extremely slow
Realthunders build has a feature freeze which could be super useful in this case
one could always also make the sketch and then at the end do the sweep
Designer | Faculty
Cekuhnen
Post by Cekuhnen »
Shalmeneser wrote: Sat Jul 17, 2021 10:06 pmFile ?
here it is:
https://drive.google.com/open?id=1TslWT ... p=drive_fs
Screen Shot 2021-07-26 at 11.39.54 PM.png (69.62 KiB) Viewed 537 times
Screen Shot 2021-07-26 at 11.40.03 PM.png (29.75 KiB) Viewed 537 times
Designer | Faculty
Cekuhnen
Post by Cekuhnen »
Forthman wrote: Sun Jul 18, 2021 8:31 am good tip for the spout, I take note! :idea: :D
you should look at the polar pattern in the final design - pretty slowing down the whole file.
to bad there is no freeze feature - one could always at least temp enter a smaller polar pattern value
Designer | Faculty
Forthman
Post by Forthman »
Yes, arrays are very slow in Part Design. :?
For perforated patterns, I try to use Draft arrays and boolean as much as possible (10x faster).
The worst thing about Part Design arrays is that the default value is 2, and sometimes instead of
overwriting the value, I just click next to it, and if I want 10 repeats, I end up with 210!!! :shock: (kill Freecad task or not :roll: )
and before you try, Techdraw is even slower to display objects containing arrays. :cry:
