Bug: Fillet breaking surface
FreeCAD 0.12
macOS Big Sur
adding a fillet to selected face consumes the bottom two edges is also quite funny File is attached
Same issue happens also with a solid loft spout
macOS Big Sur
- French Press Loft Tip.FCStd
- (43.55 KiB) Downloaded 17 times
- French Press.FCStd
- (39.03 KiB) Downloaded 11 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Re: Bug: Fillet breaking surface
BTW in part mode this works - not sure if this helps
- French Press Works.FCStd
- (29.86 KiB) Downloaded 17 times
Designer | Faculty
Designer | Faculty
I think you just discovered a new bug!
no I'm kidding (but it's pretty nice, isn't it?)
edit : the cylinder seal must not be aligned with the spout
To add to Forthman: If you take the same Body that failed and fillet it in Part workbench, it fails as well. Fillets tend to break when four edges meeting in a point are involved.
- Shalmeneser
If the fillet is not on the seam of the cylinder...
Or you can draw the fillet in the sketch.
- Snip macro screenshot-dfbf16.png (12.64 KiB) Viewed 797 times
- papyblaise
yes but there you made a teapot for right-handed people only, left-handed people will get their pants wet, choking,
but it is the right solution to avoid the shape in 4 edges which blocks the good process
I assumed incorrectly that because the spout is a different body that the filet applied to just the spout edge will result in the desired surface detail.
Designer | Faculty
Designer | Faculty
- papyblaise
what do I see on which archaeological site you found thatFreeCAD 0.12
macOS Big Sur
I did not know that the pyramids of Egipte were drawn with Fc
- Shalmeneser
Body double ?
Why 2 bodies ?
Why 2 bodies ?
Sushi tasted good for lunch.
Designer | Faculty
Designer | Faculty
