I created a box but it was too big, so my Idea was to get rid of a couple of mm in the middle of the box.
For that I created a top part and a bottom part of my box. Then I cut a couple of mm from each copy and moved the top part via transformation on top of the bottom part.
Afterwards I wanted to do a boolean operation to combine both parts again to one box into the Body "finalCombinedBox"
But whenever I use the operation the result is an empty screen.
Attached you will find the Project.
I'm using Version 0.19
Thank you!
cannot do boolean operation on two bodies
- 2021-07-16_ReduceHightInTheMiddleOfBox.FCStd
- (331.68 KiB) Downloaded 8 times
Re: cannot do boolean operation on two bodies
I'm not seeing how you made the original box. Did you delete something before attaching?
I suggest that you go and do some tutorials, your file is a complete mess and does not make any sense whatsoever.
Why do you have so many bodies? how can one have a body that contains nothing but a pocket?
A box without a lid should contain only one body, assuming it is not made from separate parts like a wooden crate for example.
Try to examine the included file.
- box.FCStd
- (83 KiB) Downloaded 5 times
- Shalmeneser
+1
- Snip macro screenshot-1b8a2d.png (98.71 KiB) Viewed 133 times
- 2021-07-16_ReduceHightInTheMiddleOfBox _Shalm.FCStd
- (288.83 KiB) Downloaded 5 times
