[SOLVED] How to make a hole in a tapered, extruded object?
TheMarkster
Re: How to make a hole in a tapered, extruded object?
Post by TheMarkster »
If I make the Extrude objects all visible the cut succeeds, but if they are invisible the cut fails. Seems like a bug since visibility should not affect a boolean operation, but I'm really not familiar with using Links and LinkGroups.
Snip macro screenshot-203e26.png (105.83 KiB) Viewed 263 times
Snip macro screenshot-67f1f9.png (101.23 KiB) Viewed 263 times
SteveDee
Post by SteveDee »
TheMarkster wrote: Sat Jul 24, 2021 10:09 pm If I make the Extrude objects all visible the cut succeeds, but if they are invisible the cut fails. Seems like a bug since visibility should not affect a boolean operation, but I'm really not familiar with using Links and LinkGroups.
Many thanks.
As a newbie I'm confused enough about FreeCAD, and not knowing if a problem is actually a feature, a quirk, a bug, or most likely me doing something stupid, is just another loose-end I could well do without. But you have put my mind at rest ...its not just me!
Thanks to all that have offered help.
