Surface Modeling: how to trim surface ?
i am trying to figure out the surface modeling abilities in FreeCAD and encounter multiple trim related issues with being unable to trim surfaces with surfaces
i made a test test scene with multiple bodies and here is a DL link: https://drive.google.com/file/d/1UEWA_s ... sp=sharing
curves WB
Trim A Face feature:
has a planar/2D trim based on an existing sketch
cannot trim a surface with a surface to my knowledge - lacks the tool to generate the intersection curve
Example: further the trim face tool has issues in my case : after trim the top face of revolve body is gone part WB
Join Feature:
can remove interior geometry of two pipe like intersecting surfaces
but this does not work with a closed surface being intersected with a plane/open surface
this makes sense this is about connecting closed shapes!
Example: extrusion is cut right - all other surface keep the surface I want to actually remove
OS: macOS 10.16
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
curves WB
Join Feature:
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.4.0
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Re: Surface Modeling: how to trim surface ?
Part WB
Slice hels splitting but it consumes the slice tool
However I can get this to model but only by using slice hiding unwanted sliced parts rebuilding the slice surfaces so i could trim them with the just created sliced edges
i attached the file
i attached the file
- Trim Surface and Turn Solid Slice Cheat.FCStd
- (204.22 KiB) Downloaded 31 times
Designer | Faculty
Designer | Faculty
for those interested this is a pretty interesting process doing surfacing:
https://www.youtube.com/watch?v=OFQGYXiCwBQ
It makes use of the Create Part command - creating a new part based on selected faces
Only downside is that this breaks the parametric link
Designer | Faculty
Designer | Faculty
To make the model parametric, why not use the "Join Curves" tool in the Curves workbench rather than the
"Shape Builder" tool to create the wires from the BooleanFragments object ?
You should add where to look at, the video is 25 minutes long. I have only watched the first 5 minutes and wasn't really delighted. Much stirring around with the mouse. Looks rather like "this is how I work" and not "this is how you can/should work".
How would this work with the surfaces to trim?
You mean after the booleanFragments command?
This design is simple enough to do it with the face trim command or model with part design WB too. Going back to my model is boolean fragment the best way to trim / split all the objects? I have not found any reference for how to trim surfaces with surfaces or find the intersection curves needed for trimming.
Min 11:28 he adds a datum plane with out showing a body from PartDesign WB - I am curious how he did that
Min 14:42 the boolean fragment
MIn 15:05 Shape Builder
Designer | Faculty
Designer | Faculty
Here is another good video
Min 0:44
So the Mixed Curve command generates the intersection of two planar curves - this is wonderful to know
Min 0:44
Designer | Faculty
Designer | Faculty
I don't use the surface functions very often so I can't give you any instructions, just a few "tricks" I've tried that work easily.
using the "Join Curves" tool often gives good results, and the edges can come from any kind of object.
a small example file to "see" how parametric it is.
by modifying the 3 sketches, the shape of "Ruled_Surface" adapts
Ah I see you - You build new faces from it.
Here is a classic problem with with the planar trim approach
it cuts through the whole cylinder
Ideally it would be super if you could mark keep and remove faces
Maybe that is why in the end the user decided to go with the shape builder even while it is breaking the parametric flow
Designer | Faculty
Designer | Faculty
Forthman wrote: ↑Mon Jul 19, 2021 12:26 pm I don't use the surface functions very often so I can't give you any instructions, just a few "tricks" I've tried that work easily.
ruled surface.FCStd
I got it to work - somewhat
mix of Part WB slice apart and Curve WB Trim Face
and a lot of cross referencing .
when adjusting a sketch things can easily fall apart
like trim a face not updating right .
or not - odd - tried ti video record a sketcher issue flipping a constraint sketch
the issue was a now show and also trim a face updated right ?! confused ...
here is a screen recording
https://drive.google.com/file/d/1HXLi1m ... RRJNB/view
I attached the file if you want to look at it
would be killer if FC would have a make solid from surrounding surfaces
- Trim Surfaces worked.FCStd
- (242.31 KiB) Downloaded 33 times
Designer | Faculty
Designer | Faculty
