@keithsloan52 What I'm doing right now is doing the same with my original description.
I'll let you know what the result is. Could be to morrow.
Update: 2021-07-23 17:45
I've downloaded the modded-file and changed the expression {color()} into {color("tan")} to have a clear indication that all colors are named. Then I went through it step by step all the way from 1 till 13.
Some interresting observations come out running under MacOS 10.15.7 (Catalina) and MacBookAir (4,1).
The first block, trianges 1, 2 and 3, in the left block of the puzzle are as expected. Adding piece 4, which is identical with piece 1, everything is still ok.
From piece 5 on everything is not as expected. See the screenshot of this phase.
Q.: where does this white triangle come from?
And yes!! now I find the rules in the list of elements that shouldn't be there. That triangle and also the trapezium where meant to be intermediate steps to find the connection for the pieces in the middle.
It's there that the problem of overlapping triangles occurs.
- Modded-5-white.png (17.48 KiB) Viewed 226 times
- Modded-6-magenta.png (17.12 KiB) Viewed 226 times
Thank you very much for your help.
However, there is another observation, that you can only spot on a slower machine!!
From this model Modded-5-elements on to the end the programm generates the correct model. You can see that in a split second if you are alert. I could only catch it far in the process where the processor needed time to finish the end result.
See attachments [Modded-13-i-elements] and [Modded-13-elements]. Where the -i- stands for intermediate picture.
- Modded-13-i.png (38.71 KiB) Viewed 226 times
- Modded-13-all.png (37.48 KiB) Viewed 226 times
I'll come back to this after correcting the model.
Correcting the model gives this result.
Still a error somewhere.
Sure that the second blue triangle was not part of the puzzle, but just a tool to find some intersections. So, eliminating this brings everything back to normal.
Anyway, I can cope with this I think.
Good learning process.
Thanks everybody.
