Modifying step file with multiple shapes
I have been trying to make a very simple modification to a step file that I imported. Creating a basefeature inside a body, and then attaching a simple sketch of a circle will not pad or pocket. The entire 3d view just disappears when I try it.
After farting around for about an hour, I discovered that if I go into the step import settings and uncheck the compound option, and bring the step file in as individual shapes, I can then do a part>fusion on them, then create a basefeature of the fusion and I can sketch a little circle on a face of the basefeature and pad or pocket will work.
Can someone explain to me what is going on here and why this behaviour is the way it is ?
Thanks !
OS: Windows 10 (10.0)
Version: 0.20.24894 (Git)
Hash: a378b6b66f8a5992fc1452567ff59bdb613abc80
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Thanks !
Qt version: 5.12.9
OCC version: 7.5.2
Re: Modifying step file with multiple shapes
Are you able to share an example file?
Regards / Viele Grüße
Max
Max
- thomas-neemann
These aren't example files we can play with.thomas-neemann wrote: ↑Thu Jul 22, 2021 6:06 amhere are some examples
https://www.youtube.com/watch?v=q_gpAeRvgvE
https://www.youtube.com/watch?v=85F7oPgxLYw
https://www.youtube.com/watch?v=eZUUIQe1pIA
https://www.youtube.com/watch?v=HJy7EM0YF_E
- thomas-neemann
I can try to find the files again and post download links.
- thomas-neemann
- thomas-neemann
I have taken a look at this file (and a couple other STEP files) in FreeCAD 0.20 with both OCC 7.3 and 7.5.
Observations:
In other cases where the sub elements don't pass geometry/BOP using a compound or sub element is not going to allow work on a BaseFeature of the failed geometry.
Whether this is an inherent "feature" of STEP files (that being sub elements intersect), poor production of the STEP by the source software, or an issue in the OCC engine...
If the goal is to create a new component using dimensional cues from the STEP file, then a ShapeBinder from the STEP import seems to be fine, since there is no attempt to change the geometry of the actual STEP import.
Observations:
- In the case of the NEMA17 STEP file, the sub elements pass Geometry/BOP check when imported with merge to compound disabled.
- When the file is imported with merge to compound enabled or if made into a compound after import, the resultant shape or compound fails geometry/BOP check. (mostly, large numbers of self intersects)
- In several other STEP files, the sub elements don't pass geometry/BOP.
- thomas-neemann
in my customers, step is mainly used to refer to purchased parts. in rare cases the parts are reworked e.g. additional hole.
Greetings Thomas
Greetings Thomas
Interesting. It seems drmacro has confirmed my findings which is good. Step files are rarely modified with my workflows but there are some and knowing these potential pitfalls will minimise the rage going forward (at least with importing step files )
Geometry/BOP is something I'm not familiar with so I need to study up on that. I also need to start writing all these little tricks and procedures down regarding working with step files before I forget and a month from now end up back where I was last night. This does bring up the question though - is there a comprehensive dissertation on this somewhere that I'm not aware of or perhaps some places I should be reading? Thanks for all the assistance!
