I was trying to figure out after Chrisb mentioned that in Design WB the Shape Builder command could produce a solid from a set of surfaces that watertight enclosure a volume.
Does this only work when the faces got trimmed / split before - aka the Shape Builder has no trim surface command build in?
OS: macOS 10.16
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
.Boundary fill - solid based on enclosed volume from surfaces
- Boundary Fill.FCStd
- (67.3 KiB) Downloaded 13 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Re: Boundary fill - solid based on enclosed volume from surfaces
"Shell from faces" needs faces that indeed form a shell.
Please use the notions which are well established in the FreeCAD world. There is no Design workbench in core FreeCAD and it's even worse that you seem to denote with this term different workbenches.
yes should have said part wb not design wb which does not even exist - yet you knew also what i was referring too
Designer | Faculty
Designer | Faculty
I do, but others may not, while others may need this precise information, which I don't.
