[SOLVED] Problems with deformed loft and Fillet
Hello!
I try to design a part with a loft replicated nine times to assemble them to fins. However, I have two problems:
(1) My loft looks somehow deformed in the middle
(2) I would like to round the edges marked green on the screenshot (for all lofts, not just for the one highlighted), but the fillet tool fails whatever I try to make it work.
Can you give me some hints on how to correct these issues?
Please find my example attached.
Thank you in advance!
OS: Debian GNU/Linux 11 (bullseye) (GNOME/gnome)
Version: 0.20.24693 (Git) AppImage
Hash: e01f0d25d5f3ef9ceb66aa087212121e9f2f2e8b
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Locale: German/Austria (de_AT)
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
- Round Fins Minimal Example.FCStd
- (63.23 KiB) Downloaded 18 times
Re: Problems with deformed loft and Fillet
That's only a visual thing. Set the Deviation in the View attributes of the body to 0.1 and it will look good.
Oh, I see!
So (1) is solved. Thank you @chrisb!
What about (2)? Is there a manual solution to add a fillet or can Part Design Fillet be tricked to perform a meaningful fillet?
fillets are a tricky business and you case is quit complicated - freecad crashes a lot here for meSpindoctor wrote: ↑Thu Jul 22, 2021 11:28 pm What about (2)? Is there a manual solution to add a fillet or can Part Design Fillet be tricked to perform a meaningful fillet?
it all comes down to edge flow and will a fillet fit.
to have good flows make edges fillets flow over tangent
your loft sits on ring edge of the revolve and that can spell errors already
I pre rounded the revovle body edges
your model is also very small by the way
- (225.4 KiB) Downloaded 18 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Thank you @Cekuhnen!
With rounding the ring I was able to get a fillet with 0,2 mm radius - this should be enough.
Thank you for your help!
Out of interest: why do you think the model is small? I mean, it is just a minimal example with just the features in question, but the "real" model is also not much bigger than that...
i guess in cad scale is subjective - i wasn't sure if you were aware of the model scale and thus what small 0.x mm value you need for the fillet
glad this all worked out
Designer | Faculty
Designer | Faculty
It's hopefully going to be a 3D printer's heat break.
Thanks for noticing!
Re: [SOLVED] Problems with deformed loft and Fillet
No worries
Glad this all worked out
I am actually not sure if at this tiny scale working with the 3D printer and will be visible
Print very fine layers
Designer | Faculty
Designer | Faculty
Oh, sorry, I think I didn't explain that clearly :
This shall be a heatbreak FOR the 3D printer.
The manifacturing method will actually also be additive, but I will not use a regular 3D printer but something more high tech
I'll see if I can share some pictures when it's ready.
