I am trying to make a simple 4 way dowel rod fitting to 3D print. Below is the picture of my current progress.
What is the proper way to get rid of the sharp corners in the part? I can easily fillet/chamfer the edges surrounding the hole, but not the edges where 3 of them meet. Do I need to create additional geometry somehow?
What is a proper way to chamfer/fillet a three way corner?
Re: What is a proper way to chamfer/fillet a three way corner?
Hi and welcome to the forum!
I'm afraid you indeed will have to build those fillets manually as pads or pockets. FreeCAD extends fillets to tangent edges which doesn't work here.
To speed things up, think about using polar patterns.
- papyblaise
something like this
- manifold.FCStd
- (126.23 KiB) Downloaded 10 times
- manifold.PNG (19.86 KiB) Viewed 563 times
- Shalmeneser
Something like that ?
- Corpus delicti 79.png (145.1 KiB) Viewed 562 times
- TriMartolod.FCStd
- (224.09 KiB) Downloaded 7 times
or maybe round?
not the nicest model (rods need to be a bit longer), but fillets works out of the box
this one is in part wb (as counterweight to other examples)
- rodcross.FCStd
- (89.06 KiB) Downloaded 5 times
you can also select a face and then all edges will be filleted
- multiple edge fillet.FCStd
- (389.49 KiB) Downloaded 10 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
- Shalmeneser
└ Body (Body)
├ Pad (Pad)
│ └ Sketch (Sketch)
├ PolarPattern (PolarPattern)
├ PolarPattern001 (PolarPattern)
├ Fillet (Fillet)
├ Pocket (Pocket)
│ └ Sketch001 (Sketch)
└ Pocket001 (Pocket)
└ Sketch002 (Sketch)
- Corpus delicti 80.png (102.98 KiB) Viewed 505 times
- multiple edge fillet _Shalm.FCStd
- (719.32 KiB) Downloaded 6 times
ah neat example for cleaning the outside similar to boolean intersect/common
Designer | Faculty
Designer | Faculty
