Hi Freecader's
I'm having a problem with the Draft Workbench, Every time I import an SVG it comes in at the wrong size
The SVG is 100mm square and when it hits the draft workbench it's 266.65mm square
Imported as geometry, the file is definitely 100 square, imported from inkscape
Ive tried a few different configs for the SVG file
FreeCAD 19.2
Windows 10
Inkscape 1.1 also tried 1.0
also tried Affinity Designer 1.9
Same results every time
Thanks In Advance
Import SVG file wrong size
- Felix D'Kat
Re: Import SVG file wrong size
Hi Felix D'Kat, good morning to the Community!
Did you take into account the thickness of the lines?
- example.png (126.63 KiB) Viewed 498 times
Please attach SVG file
