I notice that in one case the projection correctly is inside the face but in the other case extends beyond the face
Any idea what causes this?
OS: macOS 10.16
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
project sketch on face issue
- projectCurveOnFace.FCStd
- (107.88 KiB) Downloaded 13 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Re: project sketch on face issue
Two guesses which you may investigate:
- Your model shows errors. Does it look the same if you fix them?
- One projection is on a cylinder, which is a simple form compared to the loft.
Chrisb where do you see the errors ?
What am I missing?
What am I missing?
Designer | Faculty
Designer | Faculty
- Shalmeneser
* PAD : beyond the face
* LOFT : only the face
(no error for me)
(no error for me)
- projectCurveOnFace 2.FCStd
- (132.88 KiB) Downloaded 5 times
- projectCurveOnFace 3.FCStd
- (92.58 KiB) Downloaded 7 times
There are "Link goes out of allowed scope" errors. You see them in the Dependency Graph as red arrows.
even when rebuilding and instead of blending to a solid face to a surface face the projection overshoots
dependency graph also is all green
- projectCurveOnFace clean.FCStd
- (104.48 KiB) Downloaded 5 times
Designer | Faculty
Designer | Faculty
If you want to investigate the errors, you have of course to investigate the file where the errors were detected. This is the dependency graph:
- SnipScreenshot-acc227.png (46.08 KiB) Viewed 335 times
the features are clean in each file
building blend surfaces from solid faces gives you the error in the dep graph
building it from a shell does not give error in the dep graph
however
projection error remains no matter of dependency graph error or not
this likely rules out that the error in the dep graph is a cause for projection to not work
however
Designer | Faculty
Designer | Faculty
