Easiest way to add alot of constrained holes from a spread sheet?
Locked
arifzakin38
Post by arifzakin38 »
Hi! I'm new to CAD and FreeCad.
I'm looking to design a drilling template for work.Basically a rectangle with external dimensions stored in spreadsheet (length, width) and ALOT of 5mm holes in specific places.
The spots where the holes need to be are all stored on a spread sheet.When i first attempted this, i was manually creating circles and manually constraining them.Then i learned about being able to reference a spread sheet, so it's easier to change in future.
After creating ALOT of holes, i googled to see if there might be an easier way.
So i landed at creating a macro to "automate" what i wanted.
After alot of trial and error i got to the snippet of code in the attached picture.
So far it auto matically creates a new circle, constrains the radius to a value in the sheet.
Vertically constrains first circle to "B3"mm from top edge of my object.Horizontally constrains first circle to "D3" from the Y axis centre line.
How do i add more code so the next circle's constraints are "B4" and "D4"
Is the the best way to achieve what i want?
Re: Easiest way to add alot of constrained holes from a spread sheet?
No image, no file, no FreeCAD infos - no help.
M4x
Post by M4x »
Hint: Follow the big red banner at the top and I'm certain that you'll receive assistance here :)
It's a spammer. No more effort needed.
Olav
Post by Olav »
chrisb wrote: Sat Jul 24, 2021 1:58 pm It's a spammer. No more effort needed.
Not so sure. This is a question that was first asked on Reddit:
https://www.reddit.com/r/FreeCAD/commen ... oles_from/
Reddit users often don't seem to understand how forums work unfortunately...
GeneFC
Post by GeneFC »
Locked.
Locked
