UI doesn't appear correctly.
_HG_
Re: UI doesn't appear correctly.
Post by _HG_ »
No, the themes are already the default theme, on both computers.
So, it must be something else.
/ Hans Gatu
Bance
Post by Bance »
By default I meant the theme named 'default' not the one the system came with, which in my case was macha-sea. I didn't change anything else.
_HG_
Post by _HG_ »
Yes, I also mean the theme that is named 'Default', and that is the one in use, on both the computers.
/ Hans Gatu
Bance
Post by Bance »
_HG_ wrote: Thu Jul 29, 2021 4:48 pm that is the one in use, on both the computers.
But they are clearly different from the screenshots!
_HG_
Post by _HG_ »
Yes, they look very different, but still they both have the 'Default' theme.
I recorded the desktop:
https://youtu.be/Yzqp9xWTXLI
/ Hans Gatu
Bance
Post by Bance »
Well I don't really know how else I can help, sorry.
You could try changing the locale, sometimes there are problems related to that.
heda
Post by heda »
one would have to guess that you have not installed in the same way on both computers?
clearly the default is not same, suppose you have already tried all different themes...
in any case, you can probably hack this with some hands on...
Toolbar drag handles disabled depending on Qt theme
Bance
Post by Bance »
heda wrote: Thu Jul 29, 2021 9:18 pm in any case, you can probably hack this with some hands on...
Looks like the comes back here? :o
