problem with referencing to a feature in a different body
I try to make a sketch reference in thee Base body in the sketch for the handle to the sketch for the container in the glass body
I can establish the link to the glass body but then nothing further is found
if i understand it right freecad does not allow this
and the only way is to use the spreadsheet to share a dimension or shape builder/sketch clone??
here is the link to the model file
https://drive.google.com/file/d/1TslWTn ... sp=sharing
OS: macOS 10.16
Version: 0.19.24276 (Git)
Branch: (HEAD detached at 0.19.1)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.4.0
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
Re: problem with referencing to a feature in a different body
Are you implying that you want to reference the Glass object from the Base object?
If so, then yes you'd need to use a spreadsheet, dynamic data, or other technique.
Or give @Realthunder's LinkDaily a try, it would appear the user can do all sorts in the Expressions on that build.
- papyblaise
you can perfectly use external references, but not in PartDesign,
use sketcher and you can select Glass's sketch as a reference, then either open a new body and put the new sketch in it,
or you design the cup holder with Part and you reintroduce it as a basefeature in a new body if you think it is necessary
- porte goblelet.FCStd
- (331.96 KiB) Downloaded 10 times
Good evening to the Community!
I don't know if that's what you're trying to do
- ref_bodies_different.png (170.89 KiB) Viewed 508 times
I'm not sure exactly what you're trying to do. You want to set a constraint to reference a property of Revolution001? For example, set an angle in the sketch to match the angle used in the revolution you could just do:
<<Revolution001>>.Angle
or if it's a named constraint in the Container sketch:
<<Container>>.Constraints.NameOfConstraint
The Body does not have a local scope for the names of the features. You can see this here where the Revolution in Glass was named Revolution001 since there was already a Revolution in Base.
i am so sorry for the confusion
in body "Base"
i would like to set a height of the handle
equal to the height dimension
in body "Glass"
sketch container
so I know in spreadsheet i can write down a value but i would rather like to reference between different bodies and sample from sketches and features values needed
i hope this is more clear now
in body "Base"
in body "Glass"
sketch container
Designer | Faculty
Designer | Faculty
ah interesting with <<>> you can jump right to a container
this worked
this worked
Designer | Faculty
Designer | Faculty
Huh what ? i dont follow.
Designer | Faculty
Designer | Faculty
