is Part design WB Thickeness very sensitive?
Re: is Part design WB Thickeness very sensitive?
Yeah I did that too but when I pad extruded it up to lid it extruded the wall through lid and in addition cut the center out like it was pad and pocket together
I used the face align
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
When I discuss Pad and Extrude, I always make sure to make it clear whether I am, indeed, talking about Pad or Extrude.
In FreeCAD they are similar but different.
Yes, I know full well, in other software the term "extrude" is used and in the CAD world at large it is a term used widely.
But, the difference between Pad and Extrude is a point of confusion for, especially new comers, and in conversations with old timers when the operation names are used without context.
I've helped and tutored a fair number of FreeCAD users and found it helps to make it abundantly clear.
Ok should have said used the pad tool or padded it to the lid’s under surface
Designer | Faculty
Designer | Faculty
oh man lack of offset and selecting sketch profiles for pocket or pad makes this frustrating detail to model those slots
Designer | Faculty
Designer | Faculty
Here is a thickness that works. Made a pad first and carved it up.
- Thick_build1.FCStd
- (69.62 KiB) Downloaded 17 times
- thick1.JPG (32.95 KiB) Viewed 509 times
Ah interesting
Pad up first then pocket around
Designer | Faculty
Designer | Faculty
This one does some complex thickening on the inside, around the pocket.
- Thick_build2.FCStd
- (94.37 KiB) Downloaded 15 times
- thick2.JPG (36.8 KiB) Viewed 486 times
Constrained Array in Sketcher, pretty easy, like 2 minutes. Unless your trying to follow the radius, that will take a little effort.Cekuhnen » wrote
What first came to my mind is make the slots go out of the part at the bottom and use pad and pocket to close the model again.
Regards / Viele Grüße
Max
Max
Pocket one side.
- Capture2.JPG (66.08 KiB) Viewed 459 times
