Creating ribs to match complex shape?
At times I want to create structures like ribs along a complex shape typically generated from a solid using the "Thickness" tool. The PAD tool doesn't support padding to a non-planar face. Currently I am working with the PartDesign workbench, but in the past I have use Part workbench to do a Boolean AND operation with the rough rib and original solid to trim the rib to match the shape. This doesn't seem readily possible in the PartDesign workbench.
What is the recommended way of doing this?
Thanks!
Tim
OS: Windows 10 Version 2004
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks!
Tim
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Creating ribs to match complex shape?
You can either sketch the ribs from the side or use the type to-first if you want to pad to a non linear face.
The "to first" method doesn't work as it stops as soon as any part of the rib touches the face. Likewise "to last" goes to far.
The side-pad method kind of works, but the hard part of that is matching the rib contour to contour of the face. In the case shown here, the face is is curving in multiple planes. I wasn't able to select a refence edge edge for the rib sketch either, I had to just fudge it. Then when padding it very far, as the contour changes the rib pad begins to detach from or protrude through the face.
One method I played with was to use Part WB "Section" tool to trace in 2D the contour where it is to meet the rib. Then Draft WB to convert Draft to Sketch, and use that as a starting point for the rib side pad, but still has issues similar to above if padded very far.
The Boolean AND seemed the best workaround but I can't get it work in the PartDesign WB.
Tim
Tim
It will pad using "up to face". It might take selecting a couple times, you can see that I made the boss and padded down to the complex face. You need to select the face to pad to.
- face_it.JPG (54.85 KiB) Viewed 1463 times
Pad "up to face" works until I extended the rib beyond the smooth contour in the middle into the areas as shown in red, then it gives "resulting shape is empty". It only lets me select one face, but there are 3 involved.
The side pad method is kludgey but I did get what more or less what I wanted.
Thanks!
Tim
Thanks!
Tim
Ya, I kind of thought you were merging into the sides. I use sketcher with model transparency set to a see-thru, then I can see into the solid to adjust the sketch elements. This is pretty much my work flow all the time.
In case you want to try, I have written a macro the sets global transparency, it really helps in Sketcher, 100 is the standard solid. I set to 50 or 5 while in Sketcher and 100 in normal model mode, but it can also be useful to see thru the model (for fit) outside of Sketcher.
- vis-3x.JPG (11.62 KiB) Viewed 1411 times
- Vision_3_levels.FCMacro
- (3.71 KiB) Downloaded 28 times
"To last" should work:
I may add, that To forst and To last are stable with respect to the topological naming, while Up to face is not.A Sketcher Lecture with in-depth information is available in English, auf Deutsch, en français, en español.
Chrisb
Does FC have directly model like abilities
Aka
Break the rib task into two steps
Pad it onto a compatible surface and then grow it left and right into the walls ?
Aka
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
It also gave me a "shape is empty" error when the pad crossed those lines. The line that makes boundary is a b-spline, that may be part of the issue.
I still like the method of AND'ing the rib with the original solid (before the thickness step) but I'm not sure how to do that in the PartDesign WB.
Tim
- Shalmeneser
contour of the interior face or exterior face ?
File ?
