I am making a spoilboard that is 31.75mm thick, 635mmx558mm dimensionally. I am going to be using SAE 1/4-20 round T-shaped inserts hammered in from the bottom. And then I will be milling a grid connecting each one with a right angle fence at the lower right corner as my origin.
Question - I know that I can clone things, but is there a way to automate the process hundreds of times? Perhaps automate the placement? Or do I have to place each pocket manually?
Making a spoilboard...
BOOTSTRAPPY WORKSHOP - Where we do more with less
https://tv.gab.com/channel/lowellhouser
Re: Making a spoilboard...
Depending on the workbench used you can use Draft Arrays (for objects built in Part workbench), or Patterns (for objects built in PartDesign workbench).
Thank You.
