[solved] (Dangerous) behavior from the sketcher
- thomas-neemann
e.g. When creating a sketch with references to a step model, the sketcher catches everything correctly for all geometries (line, circle, rectangle, etc.) with activated automatic boundary conditions.
except for a circle with three dots. this function is available at 0.14. it was like that until today (0.20).
I was assuming that it is the same here. the selected objects turn yellow and the result was inaccurate measurements. this can lead to expensive scrap or delays in production. something like that can shake the trust in freecad. I suspect it can be fixed. can i only switch off the circle function with 3 points for my customers until then? if yes how?
Last edited by thomas-neemann on Wed Jul 28, 2021 1:05 pm, edited 3 times in total.
Re: Dangerous behavior from the sketcher
Could you pleaseprovide an example file and share the full version information of your 0.20?
Regards / Viele Grüße
Max
Max
- thomas-neemann
the behavior can also be generated without a file. here a video
https://www.youtube.com/watch?v=VatjGQg4C9w
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.25288 (Git) AppImage
Hash: bbb557aab6129efd9486d6df19f06c2976fdb7e5
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
edit
chrisb wrote that it works on mac os.
The 3 point arc works normal in my system
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.
Branch: unknown
Hash: e8566f22bbeb0b7204e3c45519d0963e8881100b
Python version: 3.8.5
Qt version: 5.12.8
OCC version: 7.5.1
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.1
- thomas-neemann
I can confirm the issue by the following procedure, use the Create Hexagon function in Sketcher and set the across flats to be 100 mm. If you then apply a diameter constraint to the construction circle it will be 115.47mm but cancel out so it's not applied. Delete the construction circle and generate a new circle by 3 points using the hexagon and it'll be created at 115.53mm.
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.25310 (Git)
Hash: a40812dfbfeaadf31aa2b2f30216b11f1556f86b
Python version: 3.6.9
Qt version: 5.9.5
Qt version: 5.9.5
- thomas-neemann
Willem wrote: ↑Tue Jul 27, 2021 11:22 am The 3 point arc works normal in my system
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
OCC version: 7.5.1
I tried to recreate the system as exactly as I could. it doesn't work with that either.
This is also the case with windows with different freecad versions. I suspect we have a misunderstanding.
pc50@pc50-VirtualBox:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.19.24276 (Git)
Build type: Unknown
Branch: releases/FreeCAD-0-19
Qt version: 5.12.8
OCC version: 7.5.0
Development releases are for... development. So you have to use it by accepting the risks (among which are bugs, regressions,...).thomas-neemann wrote: ↑Tue Jul 27, 2021 10:46 am something like that can shake the trust in freecad. I suspect it can be fixed. can i only switch off the circle function with 3 points for my customers until then? if yes how?
Bugs are good to be reported, but assessing about impacts on user trust is not reasonable at this point.
- thomas-neemann
That's right, but I felt like I was far out of the window and told my customers that it was reliable. it is enough for me to switch off the circle with e points. i change the titleopenBrain wrote: ↑Tue Jul 27, 2021 1:17 pmDevelopment releases are for... development. So you have to use it by accepting the risks (among which are bugs, regressions,...).thomas-neemann wrote: ↑Tue Jul 27, 2021 10:46 am something like that can shake the trust in freecad. I suspect it can be fixed. can i only switch off the circle function with 3 points for my customers until then? if yes how?
- thomas-neemann
That's right, but I leaned far out the window and told my clients that it was reliable. It is enough for me to switch off the circle with e-dots. i change the title
Last edited by thomas-neemann on Tue Jul 27, 2021 1:23 pm, edited 1 time in total.
